00 monte door panel question
Old Mar 6, 2011 | 11:52 PM
thefuzz's Avatar
Exclamation 00 monte door panel question
ok I need to replace the drivers side power window swich. do I have to remove the door panel to do this or can just the panel the swich is in be removed ???
Old Mar 7, 2011 | 09:09 AM
walkingonabullet's Avatar
their are 4 screws, 2 under the handle of the door, 1 in the sail panel (the top corner of the panel thats next to the A pillar) and theirs one next to the door lock and handle to open the door, that one comes out, and that entire peice is removed, everything snaps in, before you can take out the smaller panel the lock switch has to be removed and can be a pain, the window and miror switch are 2 different bodys, the windows are easy to remove, theirs a little tab when you reach around to pull on, than you push down with a steady force and it pops out. the other one, same concept, jsut harder to get out.
to remove the door panel, once all 4 screws are out, you simply pull it off from the bottom NOT THE TOP, the top just slides down onto clamps. you pick a corner, pry it till something pops, than work your way around, and one their all off, slide up to get off the clamps that hold the top on, and done and of course, the reverse to get it back on.
Old Mar 7, 2011 | 11:31 PM
thefuzz's Avatar
so your answer is yes the door pannel must be removed !
Old Mar 7, 2011 | 11:49 PM
Enzo354's Avatar
STILL SLOW
You should be able to take out the 2 screws under the handle and pull it out.
Old Mar 8, 2011 | 07:19 AM
i was a little sleepy when i made that post, um, but yeah i think you do, depending on 7th or 6th gen, ithink that trim piece around the switches come out but i have no idea how to remove those
mrl390
FWD Tech Guides '95-'07
24
Nov 1, 2012 08:18 AM
kera356
Jun 15, 2010 08:26 PM
chevyrider08
Jul 6, 2009 08:41 PM
irocdu
May 18, 2009 02:59 AM
