ZZP Downpipe
Im looking into getting a downpipe from zzp, im not quite sure which options to get, i know chibi posted a while back a picture of which selections to make but i cant seem to find it, any help would be great, thanks
check this out, i found it in the search area, not sure if this is what you were looking for, but it may help?? the posts below are #37 and #38 of the thread for a 3.4 motor, which is the motor in you car.
ZZP Downpipe (
1 2 3 ... Last Page)
jaws2008
aussiek2000
Naturally Aspirated
Will the 2.5" downpipe with cat work on 3.4l?
aussiek2000View Public ProfileSend a private message to aussiek2000Find all posts by aussiek2000Add aussiek2000 to Your Contacts
#38
04-18-2009, 04:25 AM
biggriggs
Naturally Aspirated
You could email zzp, but I doubt it that the connection at the manifolds is the same.
You can definitely do the u-bend delete. For the 3.4L though, you won't see nearly as much of a gain as you will with the 3.8L.
-Riggs.
ZZP Downpipe (
1 2 3 ... Last Page) jaws2008
aussiek2000
Naturally Aspirated
#38
Naturally Aspirated
-Riggs.
zzp no longer sells the downpipe for a 3.4 I e-mailed them a couple of weeks ago and that is what they told me. milzymotorsports shows one but seems kinda high dollar $300 plus. so I am doing the u-bend delete and on back to duals.
from what posts I have read the u-bend delete will not throw codes. the high flow cat probably will. I think you have to get the computer flashed to accept the reading your o2 sensors get after the high flow cat install. maybe someone who has already done this will explain it better than I can.
