will a CAI for a N/A 3.8 fit a 3.4
Old 03-21-2010, 10:44 AM
02monte3.4LS's Avatar
Default will a CAI for a N/A 3.8 fit a 3.4
Hey MCF members,
i've got a 2002 montecarlo with a completly stock 3.4. I was wondering if a CAI from K&N which was made for the 3.8 would fit on the 3.4. If not, what are my alternate options? I was also thinking a wizaired CAI but i just don't know how to make them fit the intake manifold for the 3.4.
any tips are welcome!
Thanks
02monte3.4LS
Old 03-21-2010, 10:48 AM
i think there about the same price.
i would go for the wizard air kit, because of the heat shield, and insulation.
i believe that kit bolts down to the factory mounts, it even has spots for your computers. then the flex piping allows for easy mounting to your throttle body.
Old 03-21-2010, 04:32 PM
I was thinking of buying one so i asked a guy that sells them off of e-bay, he said they where all the same even for impalas.
Old 03-21-2010, 04:50 PM
I'd be very curious to see the e-bay listing for the one you are talking about, could you please post it up so I/we could see it, thanks
Old 03-21-2010, 05:07 PM
the k&n can be modified to fit but its not a direct fit at all, id like to see the ebay ad to
well the link is gone i asked him this last summer,but this is what he said: "This intake kit will also fit on the Monte carlo 3.4L V6 engine and your PCM will located behind the headliughts. thanks for asking"
his e-bay store is called chrome intakes if you want to look it up.
Old 03-22-2010, 02:09 PM
NO! im asking whether a CAI for a N/A 3.8 will fit over the stock throttle body of a 3.4 with out much modification. If I have to modify it, what do i have to do to make it work?
Old 03-22-2010, 02:33 PM
You can not use the 3.8 kit on your 3.4 because the 3.4 has the MAF sensor in the stock intake tubing and your TB is a few MM smaller, you will need to get the Wizaired kit with the drop down option that says for 3.4 engines.
Old 03-23-2010, 01:56 PM
Thanks ChibiBlackSheep! That is what i was looking for.
Old 02-22-2011, 01:22 PM
Where can I buy the Wizaired kit from? I did a small search on google but all I find are instructions.
Thanks.
Quick Reply: will a CAI for a N/A 3.8 fit a 3.4
