will a CAI for a N/A 3.8 fit a 3.4
Old Mar 21, 2010 | 10:44 AM
02monte3.4LS's Avatar
Default will a CAI for a N/A 3.8 fit a 3.4
Hey MCF members,
i've got a 2002 montecarlo with a completly stock 3.4. I was wondering if a CAI from K&N which was made for the 3.8 would fit on the 3.4. If not, what are my alternate options? I was also thinking a wizaired CAI but i just don't know how to make them fit the intake manifold for the 3.4.
any tips are welcome!
Thanks
02monte3.4LS
Old Mar 21, 2010 | 10:48 AM
mak330's Avatar
i think there about the same price.
i would go for the wizard air kit, because of the heat shield, and insulation.
i believe that kit bolts down to the factory mounts, it even has spots for your computers. then the flex piping allows for easy mounting to your throttle body.
Old Mar 21, 2010 | 04:32 PM
albert1's Avatar
I was thinking of buying one so i asked a guy that sells them off of e-bay, he said they where all the same even for impalas.
Old Mar 21, 2010 | 04:50 PM
I'd be very curious to see the e-bay listing for the one you are talking about, could you please post it up so I/we could see it, thanks
Old Mar 21, 2010 | 05:07 PM
the k&n can be modified to fit but its not a direct fit at all, id like to see the ebay ad to
albert1's Avatar
well the link is gone i asked him this last summer,but this is what he said: "This intake kit will also fit on the Monte carlo 3.4L V6 engine and your PCM will located behind the headliughts. thanks for asking"
his e-bay store is called chrome intakes if you want to look it up.
Old Mar 22, 2010 | 02:09 PM
NO! im asking whether a CAI for a N/A 3.8 will fit over the stock throttle body of a 3.4 with out much modification. If I have to modify it, what do i have to do to make it work?
Old Mar 22, 2010 | 02:33 PM
You can not use the 3.8 kit on your 3.4 because the 3.4 has the MAF sensor in the stock intake tubing and your TB is a few MM smaller, you will need to get the Wizaired kit with the drop down option that says for 3.4 engines.
Old Mar 23, 2010 | 01:56 PM
Thanks ChibiBlackSheep! That is what i was looking for.
Old Feb 22, 2011 | 01:22 PM
Bait's Avatar
Where can I buy the Wizaired kit from? I did a small search on google but all I find are instructions.
Thanks.
