what do i need to do?
Old Feb 25, 2007 | 03:22 PM
2000monteSS's Avatar
Default what do i need to do?
About a year ago i purchased 2 of the flowmaster 40 series delta flows..Im not to pleased with the sound..When the car is at idle you cant hear it at all and when i am driving you can only hear it when im goin fairly slow...i was lookin at buying the original 40 series mufflers to see if there was a difference in the sound but i figured that i would ask someone on here cuz you all know more about it than i do..ive heard alot about the u bend delete and all that but i was wanderin if i just put 2 new mufflers on if i would be satisified...all input would be greatly appreciated
Old Feb 25, 2007 | 05:43 PM
Default RE: what do i need to do?
anyone have any suggestions??
Old Feb 25, 2007 | 10:49 PM
RocknSS04's Avatar
Have you done any other mods? I definately recommend the u-bend delete and high flow cat, as long as it's OBDII compatible. O2 sim' might be necessary otherwise. Cold Air Intake?
http://www.cardomain.com/ride/2319272
Old Feb 25, 2007 | 11:03 PM
no all i have right now are 2 flowmaster 40 series delta flow mufflers...everything else is stock...what do u mean when u say high flow cat and 02 sim and how much more would that cost...i am already looking at the u bend delete and the u bend replacement
Old Feb 25, 2007 | 11:46 PM
2000_BLACK_SS's Avatar
You could get an entire down pipe with u-bend delete and high flow cat of http://www.zzperformance.com/grand_p...&catid=110
If you would get this set up it would increase the sound of your mufflers with no problem
then here is the o2 simulator
http://www.3800performance.com/Merch...oduct_Count=17
I have this simulator on my car with no problems at all and i have a down pipe and high flow cat and u-bend delete and it made my exhaust louder and it sounds great now.
Old Feb 26, 2007 | 10:24 AM
wiz kidd's Avatar
seeing as though you already have the cold air intake, you should get rid of the u-bend, put a highflow cat on, and get rid of the resonator, this will free up the exhaust lots, and then you will definetely notice a sound difference @ idle
Kostya Valerio
15
Jun 14, 2015 09:52 PM
nebstewart07
Jun 19, 2009 08:38 AM
00SSsupercharged
Apr 29, 2009 09:45 PM
mickey
Aug 23, 2006 05:31 PM
