What can fit under the hood?
Old Aug 18, 2010 | 10:14 AM
Budsjlm's Avatar
are you removing the stock computer? if not your going to run into issues becuase the stock q jet is comp controlled , you will need to get a vac advance dist base to make it run correctly, there is a write up in the 4th gen how too's
Old Aug 18, 2010 | 03:49 PM
sideways's Avatar
Should fit w/ no problems. if it is a little tight get a drop base air cleaner.
Nightmagic11801
May 30, 2014 10:53 PM
84GouchoSS
Aug 18, 2010 07:46 AM
ralphtrent
Mar 31, 2007 10:51 AM
rcohen
Jan 25, 2007 11:10 AM
06BlackSS
Nov 1, 2006 04:52 AM
