trying to fit K&N cold air on 3.4L V6
Old 01-19-2008 | 01:56 AM
Andy's Avatar
Default trying to fit K&N cold air on 3.4L V6
I have the an 02 monte carlo with the 3400 and the only cold air intakes I can find are for the 3.8L,has anyone tried fitting that on? I've heard of people can doing it. If you can help me out with this it would be greatly appreciated.
Old 01-20-2008 | 01:28 PM
vita's Avatar
Default RE: trying to fit K&N cold air on 3.4L V6
hey man! I know the 3.4 has a wizaired CAI from K&N... I have one Ill see if I can find you the website I got it off of!
Old 01-21-2008 | 02:47 AM
Andy's Avatar
wow really? If you could thatd be really great. thanks alot. also what else do you have for your 3.4? Im having problems looking for parts
Old 01-21-2008 | 10:09 AM
purewhitemonte's Avatar
Been considering one of these also. So let me helpout with the links:
Here's the one for more info on the Wizaired:
http://www.easyperformance.com/
Then under the products menu, select Wizaired CAI under the Intake Category. They'll give all the specs, tech and perfomance info, dyno readings, and FAQ's.
To purchase it, go to the link:
http://www.zzperformance.com/grand_p...&catid=113
Model would be the 3400 series, and then you have a choice of getting it with or without the K&N 9 inch filter (extra $44).
Old 01-21-2008 | 09:46 PM
Andy's Avatar
ok im checkign it out right now, thing is im nto too good with cars im kidna new to this so will someone like me with little to none engine background be able to install this?
Old 01-25-2008 | 01:05 AM
On Easyperfromance's website, they have instructions you can download as a pdf file. If you can follow the steps they have in it, then you should be able to install the kit.
Old 01-31-2008 | 07:53 PM
MotorTSki's Avatar
I hate to speak out of turn as a noob to this site but.....what is the answer to the initial question? I'd like to know myself. Will the K&N system fit on a 3.4 with little or no modification?
Old 01-31-2008 | 09:54 PM
I personally have not looked at the CAI or FIPK kit that K&N has. Don't know if there is a difference on the throttlebody, but have heard and read that there is between the 3.4L and the 3.8L engines.
One other difference is the MAF (Mass Air Flow) sensor is on the throttlebody on the 3.8L while the 3.4L has it between the throttlebody and the filter box.
I do know they only recommend it for the 3.8L since that is what the website states. For the 3.4L, they only recommend strictly a square shaped filter thatfits inside the stock air filter box.
Old 01-31-2008 | 10:54 PM
MotorTSki's Avatar
so in a nutshell. If you wanta premade CAI and have the 3.4, Wizaired is the route to take
Old 02-01-2008 | 08:49 AM
kweef's Avatar
yah go with one that is made for the 3.4 and then ur gauranteed no extra problems lol
siouxcity04montess
06-05-2010 05:49 PM
mcarloss04
02-09-2006 09:09 PM
01blackmonte
08-24-2005 08:21 PM
nj85z28
06-15-2005 01:43 AM
Crimsonslayer
12-02-2004 03:37 PM
Quick Reply: trying to fit K&N cold air on 3.4L V6
