TOG Headers....
Old Sep 20, 2007 | 10:05 PM
  #41
04 Intimidator's Avatar
Default RE: TOG Headers....
I'm going to get Volts, O2, KR
Old Sep 20, 2007 | 10:07 PM
  #42
ExplosiveSoundz's Avatar
are you going aeroforce for one of them? cause the Aeroforce can do o2 and kr in the same deal...
Old Sep 20, 2007 | 10:09 PM
  #43
RPM
MPH
Intake Air Temperature
Mass Air Flow Sensor Frequency
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Injector Pulse Width (bank 1 and 2 if supported)
Long Term Fuel Trim (bank 1 and 2 if supported)
Short Term Fuel Trim (bank 1 and 2 if supported)
O2 Sensor Voltage (bank 1 and 2 if supported)
Manifold Pressure in PSI (Boost pressure for factory
turbo/supercharger applications)
Ignition Advance
Knock Retard
Engine Run Time
Battery Voltage
Transmission Temperature
Idle air Control Counts
Throttle Position Percentage
Throttle Position Voltage
Engine Load
Oil pressure (some 8 cylinder engines)
Fuel economy (vehicle must have a MAF
Horsepower sensor for these 2 items)
Two user configurable analog inputs
Old Sep 20, 2007 | 10:18 PM
  #44
O2 and Battery Voltage are the only 2 I'm really concerned about. Everything else is in the bag.
Old Sep 20, 2007 | 10:20 PM
  #45
Didn't dropping to that 3.4 put the psi over your limit on the factory dash?
Old Sep 20, 2007 | 10:24 PM
  #46
Right around 9-10 ish. I am thinking of getting one that goes over 10 psi but that is on the back burner. I can scan for that for now.
Old Sep 20, 2007 | 10:26 PM
  #47
Well, Rather than running a whole damn tube to a manual boost gauge, luckily the Aeroforce does that for me
Old Sep 20, 2007 | 10:30 PM
  #48
Bonus!!! I think I need to get some that are back lit red.
Old Sep 20, 2007 | 10:33 PM
  #49
Ugh, I guess to each their own, but I HATE the color red for LCD's. I like red,but Red LCD's **** me off. haha, I know that sounds weird, and I cant explain it.. they just make me angry...
And I was just thinking about something.. by you putting those headers on, I bet you lost 1-3 psi. So before the headers, I bet you were running around 12-13 PSI...
Old Sep 20, 2007 | 10:34 PM
  #50
UGHH
lmao
