Strange exhaust sound
Hey everyone so today I started up my Monte and noticed a strange noise come out of the exhaust. So I shut the car off and went around to the back and use the remote start so I could listen and it sounds like it is coming from the left pipe. When my camera gets done charging I will make a quick video as I'm sure hearing it will help you guys help me determine what the problem is. It is really strange. I have never heard this sound until today. It also had a strange tone when you actually drive and like I said, it is only out of the left side. It's strange, but I'll post a video up here in just a couple minutes.
So naturally when I went to go take a video of it the car didn't do it. I'll keep an ear out and see if I hear it again. It was strange though. It was almost like a pop or a crackle type sound but it also didn't quite sound like a backfire or anything like that. It was a strange sound. At first I thought it might have been a hole in the exhaust that just came through but if it was you would think it would be doing it more often and more constant. My car was a northern car, that made it's way down south which is where I got it, so it does have a pretty big amount of rust on it which is why I thought it may have been a hole. But now that it isn't doing it anymore, I have no clue. If anyone has any ideas I'm all ears. I know it's hard to give a diagnosis when you can't hear it. but if anyone has an idea I would appreciate it. Thanks
there is nothing worse than the intermittent noise without hearing the problem it is hard to diagnose or offer too much information on how to fix the problem. Could be a loose hanger on the exhaust causing a rattle, but it sounds more mechanical from your description. I would start by checking the plugs and wires (personally) just in case one of them was loose causing a mild misfire or one of the plugs is bad. If it is running smoothly and idling fine this may be a waste of your time, but with the intermittent problem the hardest part is actually diagnosing what is causing the problem.
Mine started the same thing last week. Almost a "chuffing" sound. When I looked under the car, there was excess carbon everywhere. It looks like the top of my right muffler has rusted completely out. The hangers were fine. I had to feel the top of the muffler to discover that it was damaged.
6th Gen ('00-'05): Steering Issue strange sound
silverodo12345
01-09-2013 03:41 PM
5th Gen ('95-'99): Strange sound after Uim replacement
BlownUptoHigh
03-29-2012 11:32 AM
