straight piped 3.4?
Old Nov 19, 2009 | 04:01 PM
there wont be enough back pressure for the engine youll suck down a valve.
Please explain- I've never heard of a car sucking down a valve... what does that mean anyways?
Old Nov 19, 2009 | 05:32 PM
mrl390's Avatar
I was wondering the same thing. Again, <facepalm>
Old Nov 19, 2009 | 08:09 PM
nolan28's Avatar
would a flowmaster make it a deep rumble cuz thats what i'm looking for
Old Nov 19, 2009 | 09:21 PM
Budsjlm's Avatar
go onto you tube and put in exhaust on 3.4 monte listen to different once
Old Nov 19, 2009 | 09:47 PM
monte07's Avatar
what sucking a valve means to much suction at one end or anouther will will a valve down to far and bend it. or pull it out of the head compleatly and damage the engine do to lack of back pressure. if you run a car just a muffler and headers your fine running a car for a long periods with out. a muffler or some thing creating some back pressure will do that. why do you think drag cars rebuild there engens every time the event is over that is one big reason the outher is the set up. there is your facepalm moment
Old Nov 19, 2009 | 10:31 PM
TheMonteMan's Avatar
never heard of that happening.
Old Nov 19, 2009 | 11:53 PM
Enzo354's Avatar
STILL SLOW
Not to mention danger to teh manifold.
Old Nov 20, 2009 | 06:32 AM
mrl390's Avatar
I have never seen or heard anyone have that problem. Dragsters dont rebuild their engines because they "suck down" valves. They rebuild them because they are running an excess of 8000hp and they puts a severe strain on the engine components to the point they can only handle one run reliably. I would like to see one credibly article explaining "sucking down" a valve. Sounds like another one of those no backpressure myths to me.
Old Nov 20, 2009 | 09:18 AM
Budsjlm's Avatar
never heard of it eather...and have you even been to a strip other than the nationals? there are more guys that run open headers or headers and a little bit of extention off the back than there is
Old Nov 20, 2009 | 09:22 AM
Budsjlm's Avatar
people on this forum...to me what your what your explaining is inproper build, forgeting to put in the holds or breaking a valve spring and losing the holds then somthing like that may happen
