Stock intake with cone filter
@bumpin
do you have any pictures?
what's a rough estimate on how much plexi glass i would need?and price?
and the intake will sit where the stock airbox is sitting now right?
and i can just cover it leaving one end open for air entrance right which will be the side closest to my headlight?
and finally, in your own opinion, whats better
a FWI or CAI?
a FWI or CAI?
@bumpin
a FWI or CAI?
a FWI or CAI?
@bumpin
I couldn't tell you how much square footage you'd need since I haven't built one before myself- but you could get a quick measurement yourself by measuring the size of the stock airbox- and calculating the area of each side. I'd imagine a standard 4'x8' sheet of plastic would be more than enough. Price depends where you get it from, and what plastic you go with. I used to order my ABS through work so I got it for a discounted rate (not to mention, if you didn't have somewhere local that sold the stuff, I'm sure shipping sucks for a sheet). Also depends on the thickness you go with- 1/8" thick plexi is far far cheaper than 3/8".
Personally, I'd rather use regular black ABS for everything, except maybe the top- that way it'll still retain a somewhat stockish look. For me, an all clear plastic box would be a little too 'blingy', but its all personal opinion.
a FWI or CAI?
a FWI or CAI?
However, for power gains compared to price and time invested, the FWI wins by a long shot. You can build a FWI in an hour or two for little more than the cost of the filter. Connect the hose to the TB, run it into the fender- connect the filter and mount it- done. With building your own CAI box, you could spend a day or two getting something put together and measured out correctly.
Its all personal opinion- power gains should be virtually the same, especially on NA cars. The FWI will guarantee 100% cold air in- but suffers from more flow restriction due to all the extra tube length and bends. The CAI has the benefit of a super short intake tract (just as short as stock, if not shorter)- but suffers from heat leaking into the box or around the box edges if its not sealed correctly. Either way- you're not talking a massive power gain- even if one makes 1 hp more than the other, you won't really be able to tell anyways.
Red Nightmare
01-23-2013 02:52 PM
lbtheoneMC79
09-17-2007 06:23 PM
sorcier11
05-02-2007 02:18 PM
