So, questions on air intakes...
Old Sep 11, 2012 | 07:10 PM
jdy3239's Avatar
Awaiting Email Confirmation
Default So, questions on air intakes...
Sorry is there is another thread about this already I apologize. I have a 2003 Monte LS, and I had a friend say i should put a cold air intake on it just for kicks. I read alittle on the forum, and I read that short rams dont make a big difference in preformance, due to it sucking the engine's heat cause its not going straight to the bottom of the car.
So the questions are... (and btw, I'm not really good with mechanical jargon, lol)
1. Would it be fine to put the short ram on?
2. Could you run the air intake to the bottom of the Monte?
3. What would be the price? (estimated of course)
Thanks for any replies guys.
Old Sep 12, 2012 | 08:52 AM
Not really. it would make your throttle feel peppier, but it would pull timing and make your car slower.
You could do that, however you need to be careful of putting it too low where it sucks in moisture or can get damage.
Building it yourself? About $50-$75.
Buying a full CAI kit? Around $240
Here's a kit for the LS: Easy Performance - Wizaired Cold Air Induction System #EP-CAI
Old Sep 12, 2012 | 09:34 AM
Heres one old thread with some store bought and home made versions. https://montecarloforum.com/forum/he...e-yours-15030/
Zjerry has a really nice one he made so does 03JGMonte
Old Oct 10, 2012 | 11:41 PM
MarkoE500's Avatar
i was wondering the same thing, my question was i have the 3400 i was going to just make a custom one and shove it down near my driverside wheel well..and so that would be technically a COLD AIR not a short ram...so i would actually recieve power off of that...but since you guys are talking about it picking up heat from the engine..i should probably put a plastic box around it near the areas where the engine (back side of filter bascially) would be **** to get hot air onto my filter..and id be set...would that work?
Old Oct 11, 2012 | 10:42 AM
If you have a way to monitor your Intake Air Temperatures (a lot of gauges can do that) just monitor those. If the temperature gets any more than 5 degrees higher than the outside temp, then you should seal it off.
TMoney
Aug 25, 2013 09:49 PM
ShadowX760
Apr 22, 2013 05:32 AM
Tarque12
Jul 20, 2007 07:53 PM
Ca$$e
48
Aug 4, 2005 02:20 AM
Darkness98
Jul 1, 2005 03:17 AM
