6th Gen ('00-'05): resonator
Old Aug 17, 2012 | 06:50 AM
Default resonator
What does the resonator do and do I need it because I see a lot people that say they just delete it.
Old Aug 17, 2012 | 07:52 AM
Mike 00LS's Avatar
Think of it as a larger muffler. It's just designed to quiet the exhaust and remove some of the rasp from it.
You don't need it... the stock ones have a tendency to rust through anyways, but I wouldn't dump it all together, if you're going for sound, get a glasspack that's about 16-18" and have that popped in instead.
Old Aug 17, 2012 | 10:09 AM
That's what mind did and I wasn't sure if I needed to get it replace plus I would like more sound than what is there. Thanks for the feedback.
Old Aug 17, 2012 | 12:05 PM
I tell people to think of it like a "pre-muffler", does just what Mike 00LS said. I had an issue where I blew baffles in a couple aftermarket replacements. I say ditch the thing, put a pipe in and NEVER look back!! lol!
Old Aug 17, 2012 | 12:54 PM
turbo monte's Avatar
as stated already it is not needed but without it you will get more of a raspy sounding/louder exhaust. i say delete it or replace with a glass pack your choice.
Old Aug 17, 2012 | 03:30 PM
bearbear3_4's Avatar
Resonators work with the muffler to reduce noise, by making sound waves "cancel each other out." If you drive a lot I recommend replacing it not just deleting it. The drone gets annoying after a few minutes. The only gain you get is noise.
Old Aug 17, 2012 | 04:50 PM
It must be how my Monte is, I have no complaints of the exhaust sound. I don't feel it's droning at all, I still have factory mufflers. But I do have a PLOG and ZZP DP with high flow cat..... So I wonder if those make some of the difference.
Old Aug 18, 2012 | 02:52 AM
S.O.G.'s Avatar
I have speed daddy headers, deleted res and 3 inch piping to stock Mufflers and my car is quieter than it was stock! Lol til i hit my gas it sounds a bit better but if it hits about 6rpms its raspy as hell!
Old Aug 29, 2012 | 11:37 AM
Racer23's Avatar
whats the pipe diamiter for the resonator ? i need to delete mine
Old Aug 29, 2012 | 01:00 PM
tshorty454's Avatar
THAT WOULD BE 2.25 DIAMETER FYI.
