Re-programming the Computer
Old Mar 15, 2007 | 06:13 PM
ajsbengals's Avatar
Default Re-programming the Computer
Hey guys, I started looking at chips/programmers to beef up my stock computer. Im curious as to what others have used if anything at all.
I drive a 2001 Monte LS, 3400 Motor. Any Ideas?
Old Mar 15, 2007 | 06:22 PM
wiz kidd's Avatar
Default RE: Re-programming the Computer
i know superchips make a great programmer...i used it on my truck and was really happy with it...as for the monte i'm not 100% sure..but i'm sure it would work good on it...
stay away from plug in chips though...go with a programmer
Old Mar 16, 2007 | 02:02 AM
batman's Avatar
i purchased a pcm from milzymotorsports.com, and am very pleased with it. they custom tuned it and shipped it for under 200 bucks, pretty sweet check them out.
Old Mar 17, 2007 | 10:11 AM
04 Intimidator's Avatar
Do you have any other mods done to the vehicle or plan on doing anything to the car? If it is bone stock, just get a Hypertech PowerProgrammer. They are very limited, but do the job. If you do any modification, then go for a PCM from Miltzy or ZZPerformance.
If you plan to do alot of tuning, then pick up a DHProgrammer - pfyc.com or 3800performance.com.
Just FYI, the programming is actually pretty good, you should consider opening the intake and exhaust first... U-Bend delete is great for that.
Old Mar 17, 2007 | 09:13 PM
ajsbengals's Avatar
Thanks for the info. So far the only things i have done to the car
1) MAF Sensor
2) U-Bend delete
3) High flow cat and muffler
Not much i know, but im planning on the computer to give me the extra kick.
Old Mar 18, 2007 | 07:05 AM
z34phoenix's Avatar
i would say get the dhp power tuner. i have one myself. its great... the powerprogramer and other hand held programers are ok, but they dont have scan/log features....
being able to scan and save a log of a trip or run with the car is invaluble! this is how you can get such great tuning without being at a dyno. you use real world data from your car and can see what it was doing and what you need to change.
$200 for a PCM! milzy is ripping people off. you can get a DHP pcm for less then $100
peoples 01 ss
Jun 27, 2014 03:03 PM
mekoku
Mar 11, 2010 05:48 PM
dirty
Feb 6, 2008 08:51 AM
04 Intimidator
Jan 4, 2008 04:44 PM
