Ported Exhaust Manifold or Power Log?
Old Dec 14, 2011 | 09:08 AM
Shandley's Avatar
Default Ported Exhaust Manifold or Power Log?
Greetings,
If you had a choice between a power log or PEM's, which would you choose? And, if you are adventurous enough, why?
Old Dec 14, 2011 | 09:19 AM
nitehawkjcb's Avatar
Plog
Even ported manifolds doesn't help the flow of that front manifold enough... Terrible design
Old Dec 14, 2011 | 09:44 AM
You can't PORT the front manifold very much because it is not round. It has a crescent moon shape.
The PLOG makes the front manifolds round and the collector is larger.
Ported rear manifold is pretty decent though if it is cheaper than a rear plog.
Old Dec 14, 2011 | 09:46 AM
Shandley's Avatar
They make rear Plogs? I've never seen this.
Old Dec 14, 2011 | 10:02 AM
It's for turbo applications
ZZPerformance - Rear Power Log for Turbo #07-01-00958
Old Dec 14, 2011 | 10:31 AM
PacerSS's Avatar
D-porting is possible and if done correctly results in better flow dynamics than round primaries due to the shape of the exhaust port on the head itself. It's D shaped as well. You can imagine if you stick a round tube over a D shaped port and run anything through it you create a turbulence due to overlap on the flat side.
Old Dec 14, 2011 | 11:45 AM
I had the choice and I went PLOG. It seems like a better idea to me (more open to flow better, removing the front mani from being a restriction in the set up).
Shandley
FWD Tech Guides '95-'07
Oct 21, 2019 09:02 PM
NewFoundJoey
Jul 13, 2009 04:11 AM
3800monte
Mar 28, 2008 11:34 PM
jay26
Aug 14, 2007 09:55 PM
