No K&N?
Old Apr 7, 2007 | 01:54 PM
Hamm's Avatar
Default No K&N?
When I do a search on the K&N site for products that fit my car, it only comes up with a stock air filter replacement. It shows the FIPK for the 3800 in that year, but for my car: nothing. Does this mean that none of their CAI will fit my car?
Old Apr 7, 2007 | 02:21 PM
wiz kidd's Avatar
Default RE: No K&N?
its the same thing it will work on your 3.4 engine
Old Apr 7, 2007 | 02:23 PM
Hamm's Avatar
Default RE: No K&N?
Awesome wiz, thanks! You always have good news for me.
Old Apr 7, 2007 | 02:25 PM
wiz kidd's Avatar
Default RE: No K&N?
no problem...always like to help out...
Old Apr 7, 2007 | 04:19 PM
Hamm's Avatar
Default RE: No K&N?
Alright wiz, just for my curiousity, why don't they list the intake for the 3.4 L's?
Old Apr 7, 2007 | 04:44 PM
wiz kidd's Avatar
Default RE: No K&N?
i think its cuz the average person that has the 3.4 l probably doesn't want a cold air intake...usually the guyz that do their cars up for speed would have the 3.8l engine..
but even if it didn't work you could find a 3.8l in a junkyard, take the throttle body off of it and put it on yours...then connect the cold air intake to it...but its probably the samealready..should be the same throttle body...i'm 99.9% sure that the cold air intake for the 3.8 will fit the the 3.4...
Old Apr 8, 2007 | 04:00 PM
z34phoenix's Avatar
Default RE: No K&N?
the intakes for the 3800 should fit the 3400 yes. Wiz FYI 3.4L is not the same as 3400 they are two diff engines... 97 was the last year for the 3.4L
as for the TB's the 3800 TB is very different from the 3400 TB. Now the 3100 and 3400 TB's are almost identical except that the 3400 is slightly bigger inside (good swap mod)
the only problems i see with the install is that the 3800's MAF sensor is built into the TB and the 3400 has an external sensor that is between the TB and airbox. worst case is that you will need to cut a section of the CAI and fit in the maf sensor some where. but obviously the engine bay is the same. if you want some info on how to build your own CAI/FWI fender well intake. go to my homepage and to page 6. i have a writeup there for my car and links to about four other sites with info more specific to your year car. if you cant find a design you like there... you prob wont find one.
Old Apr 8, 2007 | 07:23 PM
Hamm's Avatar
Default RE: No K&N?
ORIGINAL: z34phoenix
Even with your write-up, I still doubt I could pull that off. Very little faith in my abilities. So it looks like if/when I decide to try this I'll have to have someone install if for me.
Old Apr 9, 2007 | 01:44 AM
z34phoenix's Avatar
Default RE: No K&N?
where you at?
Old Apr 9, 2007 | 02:21 AM
Hamm's Avatar
Default RE: No K&N?
I live in North Dakota, if that's what you're asking. The opposite of Florida.
