muffler delete on my 02 ss from stock exhaust.
Old Nov 18, 2020 | 09:46 PM
GrayGhost1951's Avatar
'Better' depends what you're after as they serve two different purposes.
I completely agree with nitehawk though - in general muffler delete has the bigger impact on overall volume. Resonator delete tends to be more impactful on certain frequency ranges, but the overall volume change isn't nearly as big.
IMO for a 3800 car though, muffler delete is never a good route. The 3800 gets pretty nasty when it gets a lot louder than stock.
Well I had my opinion but wanted to hear from others with them. I listed to a few You Tubes and they were OK. I think I am going with losing the resonator and using some aftermarket exhaust. Flowmasters and Magnaflow are too expensive. Any suggestions? This is a dead stock 3800.
Old Nov 18, 2020 | 10:26 PM
What is your budget? Looks like the brands listed run about $75-150 / muffler.
If you're wanting a lot cheaper, you'll definitely have to ditch stainless- maybe for some Jegs mild steel mufflers - looks like they're $30-40 each. Not much below that without going to a $20 glass pack.
Old Nov 19, 2020 | 05:57 AM
Found some on Ebay but they do not list my Supercharged SS (common them it seems). Don't know if it is because it is a low production unit or that the SC version requires more flow. I sent a note to the company asking about it and they requested my VIN, which I sent. Waiting to hear back. But, yeah, I could always put Flows on it - they have about 5 different versions. But I need the Y pipe and resonator delete pipe, and hangers, etc. etc. This was a NY car at one time and has some rust issues.
Old Nov 19, 2020 | 08:43 AM
My suggestion... Delete U-bend, res, (cat if you can). Replace the stock res with a glasspack. Dont all 3800s come with dual muffler exhaust? I ask because I see you mention you need the Y-pipe.
Old Nov 19, 2020 | 11:03 AM
If your whole catback is rusted out, I'd go pick one up that's in better shape from a junkyard, then hack that up with your new parts.
If only certain parts are in bad shape, just have the shop replace those at the same time.
Id have a real hard time spending $1k+ for a complete aftermarket catback.
Old Nov 20, 2020 | 05:21 AM
Default Exhaust
My feelings exactly. I bought a new downpipe and Cat from Ebay for $120 including shipping. That part is solved. I can buy a Y pipe for $99. Just have to make a pipe to eliminate the resonator and then chose some mufflers that work. That is where I am now. The openings are complicated, and you have to get the right offset in and out of course especially for tips. Just doing research on which ones to buy. On average most are around $75 each. The trouble with boneyards is that it is labor intensive to hack one out. With the Y only being $99 I can go that way and not have to deal with rust, etc.
iMuf
Jan 30, 2013 09:14 PM
STUMPMI
Jan 23, 2013 11:16 AM
DJTJ
Mar 31, 2011 03:47 PM
M.C.BOB
Apr 28, 2009 11:55 PM
01BlkSS
Dec 27, 2006 10:57 AM
