Magnaflow muffler
Old Apr 23, 2013 | 08:20 AM
04SuperchargeR's Avatar
Default Magnaflow muffler
Looking to get a magnaflow stainless steel oval muffler for my 04 supercharged ss, what inlet outlet should i get? and what diameter in/out? my exhaust is stock as of right now
Old Apr 23, 2013 | 04:47 PM
Mike 00LS's Avatar
I believe the factory pipes are 2.5" so a center inlet 2.5" diameter would be the way to go. The outlet really doesn't matter much, especially if you plan to put tips on it, just match the outlet with the tip inlet. Stay either 2.25" to 2.5" for the outlet, though.
Remember you need mufflers (plural).
Old Apr 24, 2013 | 08:51 AM
Do you think I should get new tips? Or just keep my stock ones?
Old Apr 24, 2013 | 09:38 AM
Mike 00LS's Avatar
Stock ones are welded, so they'd need chopped off and re-welded to the new pipes.
Old Apr 24, 2013 | 12:12 PM
03SSLE's Avatar
Another consideration are the hangers on the mufflers. If the mufflers you select don't have those hangers you'll need to transfer the ones from the old mufflers over or fabricate new ones.
Maybe if you contact Magnaflow they will give you the part numbers for the mufflers they sell in the cat-back kit. Then it would be a straight forward R&R with minimal adaptation. Those mufflers have the tips already welded on too so that would be one less step to do.
Old Apr 24, 2013 | 12:48 PM
Mike 00LS's Avatar
Good point, Mike. Usually though, unless you buy a complete cat-back you won't normally get the hangers with the mufflers. Of course they'll sell you some, though.
I had to get hangers when I did my Magnaflows. For reference, OP, this is what I used for mufflers: MagnaFlow Exhaust Products - For Trucks, Suv's, American Muscle, Diesel, & Sport Compact Vehicles
They're a 2" in and out since I have an LS I needed to add a 'Y' adapter and run new pipe to the mufflers. So for a dual application 2" was good enough for me. No need for big-*** pipes - they won't work for your application however, but just to base your style off of.
EG_3Ohh
Apr 5, 2014 05:53 PM
773 Z34
Aug 21, 2012 12:52 PM
fwoggybaby
Apr 7, 2012 09:42 AM
GreenRaccoon
May 31, 2011 12:27 PM
04MonteLS
Jun 4, 2005 11:17 AM
