Knocking noise before and after blown head gasket repair!
Old Mar 8, 2013 | 06:24 PM
Originally Posted by InfamousFlip
I was thinking to swap it with a 3400 dohc motor. Hopefully that would be a easy and simple swap.
Thank you fellas for your help!
I just replied to your other thread. But to clarify here, you just mixed two different engines. There is a 3.4 DOHC and there is a 3400 OHV (I believe that's the right acronym).
The 3400 v6 looks almost exactly like your 3100. Main difference is bigger air passages and as a result, more out of the gate performance then a 3100. If you look at the Grand Am community, a common engine swap for mid-90's Grand Am owners was to go from a 3100 to a 3400. It's almost direct swap.
Going to a 3.4 DOHC will take a little more work.
Old Mar 8, 2013 | 06:36 PM
InfamousFlip's Avatar
Yeah I noticed that now lol! Totally different!
Well, I seen a remanufactured 3.4 dohc for a really good price and I was thinking about getting it. How much more complicated is it to install?
Will I need a different tranny?
Will it need a lot of modifacations?
I am trying to get idea of how much more work that will need to be done.
Will I just be better off with getting a 3.4 ohv instead?
Thanx Manic for your replys and help sir!
Old Mar 8, 2013 | 10:57 PM
I honestly don't know the difference in difficulty of going from a 3100 OHV to a 3.4 DOHC. I suspect wiring harness issues and PCM issues. Maybe trans issues. I never researched the subject, so some one else may be able to chime in with more info.
What I have read is that the 3.4 DOHC can be a little finicky of an engine (again, I cannot atest that for sure, I never researched it).
If I was pulling a 3100, I'd pop a 3400 in it's place. If you google the subject, I know the was a Grand Am write up on the subject (which would be VERY applicable to what you want to accomplish). When I read it (out of personal curiosity), it appeared very straight forward for the most part. And the write up I saw years ago talked about some of the small (and I mean small/minor) issues this guy ran into. No show stoppers in my book.
Old Mar 9, 2013 | 01:19 AM
nitehawkjcb's Avatar
Maniac - you're right. Overhead valve = OHV
OP, to swap to a 3.4 DOHC you will need the engine, PCM and wiring harness from a '96-'97 Z34, possibly have to modify axles, and your transmission I'm sure could work, but gear ratios would have to be modified in the PCM at least.
If you want a reliable swap, do a 3400. At least there is some aftermarket for them - check out 60degreev6.com they'll have a lot more info about 3400's.
Now if I had to go through all the trouble of swapping a 3.4 DOHC... I wouldn't. Much rather swap a 3800 & 4t65e. LQ1's have a slim aftermarket. I only know one vendor that makes parts for those motors, and they're fairly pricey. There is a guy that put an M90 on an LQ1 though... Lots of custom work.
Old Mar 9, 2013 | 07:11 AM
And lots of unreliable down-time too
But man does he have a sweet 5th gen
Old Mar 9, 2013 | 02:43 PM
True, and it's a 5 speed! :O
Old Mar 14, 2013 | 04:11 PM
Thanks fellas!
After doing some research I am definitly going to go with a 3400 ohv swap! Its not as difficult to swap but I would of loved to give a 3.4 dohc a shot. Forget it lol! Once thanks fellas for your replys.
z34monte95
Jan 31, 2014 09:28 PM
InfamousFlip
Mar 14, 2013 04:24 PM
ajblalock
Jan 4, 2012 08:50 PM
1996Monte_Carlo
Jan 26, 2011 09:32 PM
Montecarloguy07
Dec 8, 2009 09:29 PM
