JMB Fenderwell Intake Brace Cut
Old Jan 10, 2014 | 02:56 PM
Hiroska's Avatar
Ahhh too bad I cant do a Fender intake for my 07..I dont think ;/
Old Jan 10, 2015 | 02:16 PM
xpage's Avatar
Shandley, can you post any pictures of your final product? I'm curious to see
Old Jan 10, 2015 | 02:19 PM
Shandley's Avatar
I wont be ripping it apart but I can show you top/side view and angles to show the cuts (hopefully), if you want. It'll be Monday or Tuesday.
Old Jan 10, 2015 | 08:45 PM
owens91's Avatar
what size or brand filter have you used, mines is halfway thru the hole but not all the way in
Old Jan 10, 2015 | 09:08 PM
Shandley's Avatar
K&N. Whatever comes with the kit.
Old Jan 11, 2015 | 07:41 PM
owens91's Avatar
o0o0o0 i wouldnt use them ive heard they mess up the maf with their oil, do you know their measurement?
Old Jan 11, 2015 | 09:00 PM
xxtheshockerxx's Avatar
RED DEVIL
They only way you will mess your MAF up with the oil is if you literally soak the filter down. I have been running oiled filters for probably close to 10 years with no problems. I wouldn't worry much about the oil doing anything a little goes a long way.
Old Jan 11, 2015 | 10:58 PM
xpage's Avatar
No worries take your time. Ripping it apart would be a pain, fromt he top view is fine
Old Jan 12, 2015 | 09:08 AM
Shandley's Avatar
K&N oils do not flow through the filter onto the MAF. I too have been using them on this car for 10 years now (one for inside the airbox and now the fenderwell intake) and nothing has gone wrong. I have even 're-charged' them myself. You just have to do it right, which is not hard.
@xpage I'll likely get those pics out tomorrow
Old Jan 12, 2015 | 02:43 PM
Shandley's Avatar
Well, it's rough cut but it works well. I guess I didn't have my angle grinder or dremel around.
Cover pulled back and filter shown. You can see the larger part of the filter is out about an 1/8 of an inch. Foam gasket around the cover will cure all that ails (not installed on this one).
Right side cuts (with tin snips).
Left side (with sawz-all)
Top view, slightly larger angle, filter pulled back.
"Assembled"
Installation was a bit tight. I remember having to put the hose connector on first, then the cover, then push the K&N filter all the way on until the pipe could not go in any further, then I had to push it into the fenderwell (after it was cut) as far as it would go. At the other end, it took some magic and some bending of the rubber piece but it fit. I was then able to pull the pipe out of the filter a bit to center everything and to adjust the angle of the pipe to fit it all in as close as possible. With some foam gasket around the black cover, and only when everything is lined up, then screw in the cover, if at all (mine is still loose).
