Installed headers... *Now with pics
Old Mar 17, 2008 | 06:37 AM
bfurches's Avatar
Default Installed headers... *Now with pics
Well, it's done...
I finally installed my headers I had been waiting on with the help of billboost (one of the admins over at nebonnevilleclub.com).
I had purchased a set of the used XS Headers which were being sold on ebay a while back from a member on club gp. These are the headers that were crafted after the SLP setup, and all I can say is that they are nearly identical minus the coating. Bill currently has a friends set of SLP headers sitting at his house which we used to compare.
Size of the primaries and pipe bends are identical. Flanges are welded in the exact same manor (welded on the inside of the primary with a tack weld on the outside). Both headers had a significant amount of weld slag on the inside of the primaries and near the egr tube. (slps had more in some areas and the xs had more in others). The cross over pipes use the same slip on design, and both systems put the 02 sensor in the same location requiring an extension harness.
All and all, I would take the XS over the SLPs any day of the week. I picked up my set used for 275 shipped. A set of SLPs run for between 450-650 USED!. I dont know about you guys, but I am all set with paying an additional 175-375 for cermaic coating since essentially both sets of headers will function the same.
I will try and post up some pictures of the headers installed, and a sound clip of the 3" exhaust, headers and lack of cat...
Old Mar 17, 2008 | 07:26 AM
lav74's Avatar
Default RE: Installed headers...
Nice job pricing things out and coming out ahead! What type of coating did you get on them? I did a flat black ceramic coating on my nickel TOGs, and I'm happy with it.
Old Mar 17, 2008 | 07:57 AM
bfurches's Avatar
honestly i didnt bother worrying about coating. My iat and coolant temps are low enough where i couldnt really justify paying for a 200.00 coating job. they are just straight up stainless steel.
Old Mar 23, 2008 | 05:59 PM
bfurches's Avatar
Default RE: Installed headers... *Now with pics
Old Mar 23, 2008 | 08:50 PM
couch's Avatar
very nice. amazing deal you got there.
Old Mar 24, 2008 | 02:08 AM
rysZ34's Avatar
Very nice!
Old Mar 24, 2008 | 08:34 AM
Hi Brandon,
Thanks for sharing your information/price/pictures.
How difficult was the install ?
Can you notice the increase in power ?
Now, we need new 1/4mile times : )
You have given `up to get, & I think it's a great `mod
for your awesome SuperCharged Monte.
Look forward to updates.
Good Luck,
`Space
Old Mar 24, 2008 | 09:27 AM
bfurches's Avatar
Space, install was a little bit of a pain, but not too bad. I couldnt imagine having to do it on the ground like a lot of the hardcore DIY guys, but luckily I have a lift. The front and cross-over were cake, its the rear that is a pain. You have to roll the motor all the way forward so its practically touching the radiator to slide the rear manifold in and on the studs (or you can actually remove the studs with a 5.5mm for an aditional inch or two of clearance).
As far as increase in power, its only a tiny bit noticeable out of the box, but once i started playing with the HP tuner and adding some more timing since i was knock free, the car really came to life.
Track opens up on april 12th, we will see where i land.
All I know is that I beat up on my best friends Mazdaspeed 6 (turbo awd), which ran a 13.8 bone stock. I pull his car on the street all day long whether its from a dig or a roll.
Im shooting for 13.6 on a 3.4 and race gas on the 12th!
Old Mar 24, 2008 | 09:59 AM
[align=center][/size]Hi Brandon,[/font][/align][align=center]Thanks for your post/write `up.[/align][align=center]Yes, you were lucky to have a lift.[/align][align=center]We will be look'in forward to you post on your run's : )[/align][align=center]Those Mazdaspeed6 are a great little car with[/align][align=center]a turbo 4 Banger.[/align][align=center]You should be able to Smok'in `all : )[/align][align=center]Wish you Good Luck, Good Run's[/color][/align][align=center][:-]EnJoy [:-][/align][align=center]Watch out for `Brandon's SuperCharged Monte Carlo[/align][align=center][:-][font="times new roman"]Yes, you guys below [:-]
2006 Mazdaspeed6 Grand Touring- 2006 Subaru Legacy GT spec.B
Powertrain/Chassis
Drivetrain Layout
Front engine, AWD- Front engine, AWD
Engine type
Turbocharged I-4, aluminum block/head-Turbocharged flat-4, aluminum block/heads
Valvetrain
DOHC, 4 valves/cyl-DOHC, 4 valves/cyl
Displacement
137.9 cu in / 2260cc-149.9 cu in / 2457cc
Compression ratio
9.5:1 -8.2:1
Power (SAE net)
274 hp @ 5500 rpm -250 hp @ 6000 rpm
Torque (SAE net)
280 lb-ft @ 3000 rpm-250 lb-ft @ 3600 rpm
Redline
6700 rpm-6500 rpm
Weight to power
13.0 lb/hp-13.5 lb/hp
Transmission
6-speed manual-5-speed manual
Axle/final-drive ratios
3.94:1 / 3.35:1
4.11:1 / 3.03:1
Suspension, front; rear
Control arms, coil springs, anti-roll bar; multilink, coil springs, anti-roll bar
Struts, coil springs, anti-roll bar; multilink, coil springs, anti-roll bar
Curb weight
3574 lb -3386 lb
Quarter Mile [/size]
[size=4]14.3 sec @ 96.0 mph---14.0 sec @ 96.5 mph
Braking, 60-0 mph
113 ft -122 ft
Base price
$30,555 -$34,620
Price as tested
$31,255 -$34,620
[/align][color=#0000ff]Previous
|8283 | 8485 | 8687 | 8889 | 5 | 9091 | [color=#810081]Ne
[/align][/align]
Old Mar 28, 2008 | 04:44 PM
04 Intimidator's Avatar
I picked up my SLP's for $600 and had to do a messload of work to install them. This kit you have is a much nicer design.
zjerry
Sep 7, 2011 05:45 PM
05montess
Feb 21, 2011 05:08 PM
davidk67
Sep 4, 2010 11:42 AM
04SSMonte510
Dec 24, 2009 05:19 PM
88montessman
Feb 26, 2009 06:37 AM
