I am about to order a 180 T stat
Old Mar 16, 2011 | 12:05 AM
02montecSS's Avatar
Default I am about to order a 180 T stat
Should i go drilled or non drilled?
and is the installation easy?
Old Mar 16, 2011 | 08:07 AM
Do you use your heater in the winter? If so then don't drill it.
Installation is a piece of cake, should only take about 10 minutes.
Old Mar 16, 2011 | 12:20 PM
02montecSS's Avatar
I use my heater alot in the winter so it looks like im going un-drilled!thanks chibi!youre the best!
Old Mar 16, 2011 | 04:13 PM
biggriggs's Avatar
If you're really from southern cali, then winter temps aren't cold enough to make a difference between the two honestly. You won't notice a difference until it's well below 40*F.
Old Mar 23, 2011 | 03:40 AM
02montecSS's Avatar
So is a drilled t stat better?
I haven't ordered it yet because I decided to wait until I order my u bend delete and cat
Old Mar 23, 2011 | 07:39 AM
I don't think you need to bother with drilled.
God_Bot
FWD Tech Guides '95-'07
Mar 6, 2013 12:42 AM
Super Strong SS
Mar 24, 2010 08:20 PM
03SS
Nov 11, 2008 10:15 PM
v8_Killa
Aug 31, 2008 06:55 PM
derrel96ls
May 4, 2007 09:41 PM
