t stat question
Old May 3, 2007 | 06:52 PM
derrel96ls's Avatar
Default t stat question
what is the best t stat to run in our cars? i have a 180 drill t stat is that a good one??
Old May 3, 2007 | 08:18 PM
mickey's Avatar
Default RE: t stat question
yeah it is pretty good for a car in a mild climate. OR if you dont mind not having real hot heat in teh winter you can run one also .
If you live in a hot climate then a colder version like a 160-180 would be better to help keep teh motor runnign cooler.
jus tlook at it this way Heat is a Enamey of your motor the more you can take out with out screwing up the internals of the computer the better you are.
this can be done threw the T-stat, threw a vent under the hood etc.... the lees under hood heat for the motor to run in the better it is for you and the cars
Old May 3, 2007 | 10:52 PM
z34phoenix's Avatar
the 160 is too cold. even for moderate to heavy mods... back in the day before tuners people used them to fight engine Knock with the SC cars, but now with the tuners and fan controlers they arent needed. and most 2000+ cars will set an engine light with a 160* stat. the car thinks its not warming up correctly and will set a code.
bottom line is the 180 is fine. i personally run a 180 stat and have my fan times adjusted. in the florida heat! even in traffic my car is about 185* max. and when driving its about 176* basicly the target coolent temp is 175-190 for most engines. the higher temp will be better on gas and emissions, but wont reduce as much Knock and cause more heat soak. (which reduces peformance)
Old May 4, 2007 | 01:53 AM
mickey's Avatar
yeah what he said LOL
Thansk for the info on that one Like you said I used to use the 160's in my old motors to help fight the heat i had with them in there.
But glad to knwo tha thte 180 is the limit on this one.
But have to find one that is drilled if i can or do it myself just been a while since i drilled one and cant remeber how big of a hole to put in them.
I belive it was4@ 1/16th holes around them at the 12.3.6.10and
Old May 4, 2007 | 02:47 AM
z34phoenix's Avatar
the drilled stat i have has only 2 holes in it and they are about a 1/16th
Old May 4, 2007 | 03:02 PM
derrel96ls's Avatar
yeah i live in michigan and i run a 180 drill t stat in my gtp and i seems to keep a good temperature. I didnt know if it was going to be different with monte carlos or not, Thanx for the help.
Old May 4, 2007 | 09:41 PM
mickey's Avatar
thanks Phoenix, For the info. I still havent bought one for mine but then it is still in teh body shop also. So will have to do it shortly when i get it back
God_Bot
FWD Tech Guides '95-'07
Mar 6, 2013 12:42 AM
03SSChevyFun
Sep 15, 2010 10:31 AM
Super Strong SS
Mar 24, 2010 08:20 PM
03SS
Nov 11, 2008 10:15 PM
v8_Killa
Aug 31, 2008 06:55 PM
