Air intake questions,help?
Old Mar 15, 2011 | 05:06 AM
02montecSS's Avatar
Default Air intake questions,help?
Ok you guys don't be mad at me but I'm probably going to ask some questions that have been asked and answered like a million times here, but forgive me.I'm a noob with cars and this is my first car.
I currently have a HAI, I know it's bad, but that's why I'm here to ask questions. I was just wondering on what to use to make an airbox?where can I get the material from?what would be the easiest way to go about making an airBOX, not a wall.lol does anyone have any specs, instructions, and experiences with this that they don't mind sharing with me?
Also, is an FWI more effective than a CAI? I know gains are minimal on N/A cars but which one gives more low end torque,if any?
Old Mar 15, 2011 | 07:11 AM
A FWI isn't more beneficial than a proper CAI, they are just easier to make because you don't need to build a box.
To build a box, do some research on materials that reflect heat, use cardboard for a template, then make a box from that.
Old Mar 15, 2011 | 04:49 PM
X2 just use cardoard and tape to make template
Heres a pic. of one I made ....
Old Mar 15, 2011 | 07:15 PM
02montecSS's Avatar
ok so if the CAI is done properly, it should be atleast somewhat more efficient right?or are they basically the same, just different cosmetically?
@zjerry, where can i find scraps of aluminum like that?and the coupling with the extension can only be found at autozone?i went to home depot once looking for something similar to that but no luck.While i was there i was also looking at aluminum sheets, but i think i need to add an extension to the tube first. and what did you use to cut the tube shape for the aluminum box?do you have it insulated?if so how did you insulate it?
Old Mar 15, 2011 | 09:09 PM
Old Mar 15, 2011 | 10:52 PM
Ive been thinking about building a box from this. maybe you could try this.http://www.homedepot.com/Building-Ma...atalogId=10053
Old Mar 15, 2011 | 11:31 PM
02montecSS's Avatar
that doesnt seem like a bad idea, considering that thats insulation wrap. Itll skip the whole step of insulating any box i make.it probably wont be the best looking one but should get the job done right?
so i plan to get the extension and the make a box out of this material and mount it where the original air box used to go.time to start taking down measurements i guess!thanks to all you guys that sent me in the right direction with this!
Old Mar 16, 2011 | 08:08 AM
CAI and FWI are just 2 means of getting COLD air to the engine. They are only different cosmetically (unless your FWI has a lot of bends in it that restrict airflow)
Old Mar 16, 2011 | 02:40 PM
02montecSS's Avatar
does any one know if that material is stiff to create a box?or will i need to has something stiff to connect the ends to form a box
Old Mar 16, 2011 | 02:53 PM
02montecSS's Avatar
came across this person's idea.
pretty ghetto, but i do live in the ghetto after all!lol
i like it tho
what do you guys think?
http://www.audizine.com/forum/showth...-for-under-75?
when he started, you would think that its going to look crappy and what not, but the final product actually looks nice!
