Help!!!!!!!!! Zzp downpipe
Old Sep 6, 2013 | 02:34 AM
augi's Avatar
Default Help!!!!!!!!! Zzp downpipe
As the title states, I need help... I just purchased a zzp 3" dp for my 99z34... I'm having a problem with fitment. I realize its different between the 5th gen and the rest, but the problem isn't in the bodg , (I got that hammered out)instead, its I. The manifold. I have a 1/8" or slightly less gap in the top... the bottom mounts just fine. Just as an idea, I still have the 1"shorter dog bones because the car is lowered 2". If I were to remove those and put the OEM dog bones in, would that possibly help me? Would that hinder the axels because of the car being lowered? Any advice e appreciated
Old Sep 15, 2013 | 09:16 PM
z34phoenix's Avatar
I cant say for sure because i am running headers. But i would start with stock size upper mounts. there is no axle issue with stock upper mounts. nice to see another 5th gen. whats your plan for it?
Old Sep 16, 2013 | 02:27 PM
augi's Avatar
I thought you would still run into issues with headers, I have a bunch of supporting mods gearing toward a turbo, but with the problems I'm having with the DP, Im thinking against it and possibly going with a s/c instead. I want 400whp out of the car, along with some thicker sway bars and stiffer end links, and if I could find some poly or hardened body mounts, then those as well. I just want the car to handle lore than go super fast straight.
Old Sep 16, 2013 | 04:42 PM
z34phoenix's Avatar
Well headers need lots of cutting and pounding to fit. For the power level you want a turbo is the way to go. With the correct upper mounts that down pipe should fit fine.
As for handling: I would get a set of the bmr rear trailing arms and lateral arms and strut tower braces. That will stiffen it up. Then get eibach springs and kyb gr2 strus. Then a set of wide tires 245's. and you should be golden!
Old Sep 16, 2013 | 10:07 PM
nitehawkjcb's Avatar
I'm surprised you left the dogbones on while doing a downpipe install to be honest
Old Sep 17, 2013 | 07:57 AM
augi's Avatar
The hammering is what's driving men up the wall... I really don't want to cut anything, but I fear I may have to. I actually got a hit fed up with the whole thing and left my car with a mechanic to cut the DP and weld the flange at a better angle to fit. It seems that when it was made, the flange that boldlts to the manifold was welded on at a steep angle that makes everything hit the firewall before the top actually mates to the manifold... so were angling it down.
About installing with the dog bones, I just figured if it doesn't fit with them then it doesn't fit.
Also, the current suspension I have is solid trailing arms, sprint lowering springs, and custom strut towers.
I couldn't find eibachs for a 5th gen, as well as the lateral arms
Old Sep 17, 2013 | 02:10 PM
augi's Avatar
Fixed it... all I had to do was cut the do in two places and weld it back together. Still high flow, not near as pretty.
Pure2sin
Nov 28, 2009 09:29 PM
jaws2008
Oct 10, 2009 06:02 AM
ChibiBlackSheep
Jun 13, 2009 11:37 AM
ChibiBlackSheep
May 1, 2009 02:50 PM
wroeber_55
Jun 3, 2008 06:48 PM
