Flexible tubing intake?
Ryan, I don't think ANYONE EVER said your setup was in ANY WAY a bad setup! It's a GREAT setup! Especially for what you have into it! But I don't think anyone can argue the point that a totally smooth tube will flow better than a flexible intake of the same diameter. It's a friction thing. Your system is WAY better than stock, and honestly, flows probably all the air your engine needs.
I still believe though that IF you were to do a good dyno test comparing smooth vs flexible, the smooth would make better HP every time. Maybe small amounts, but better.
btw where did i said tube with ridge on the inside flow better than smooth tube???
all i refer to is the tube is not as bad as some people saying they are.
There are 3 main things that dictate flow through a pipe/tube:
-diameter (which is pretty much dictated for you by your TB and filter size)
-interal roughness
-bends
All I was saying was that the flexible tubing is bad for both of the bottom two things, thats all.
Im pretty sure we are all on the same page here.
i said i totally disagree with SOME of YOU, that mean couple of you. anyway bum i'm not going to argue with you over who's right. i guess i should explain clearly on my statement first for confusing you my fault. i was more focusing on that you can make the tube work like any fwi without spending alot of $$$. im cool here. peace!!
home depot doesn't sell the corrugated tube. i got mine from intense, wbody store and zzp also have them too. you need about 3.5'' to 4' long and also get the short stainless duct tube to connect from the filter to the tube so the filter won't fly out like bum mentioned. 3 ring clamps size 3.5" to 4" and iat harness.
http://www.wbodystore.com/grandprix/...ness-p-65.html
