Flexible tubing intake?
I would never use flexible tubing because of all the ridges on the inside the air has to pass over. It would be ok for a temporary intake but if it were me I would either get some tubing bent or get some straight pieces and use some couplers to put the bends in that you need.
The flexible tubing is used for those who want to put the filter in the fender as cheap as possible (since it generally much cheaper than even pvc pipe, especially with all the bends).
One downside is you'll have to find a way to secure the filter- to 'hang' it, because the flexible tubing will not support the full weight of a filter, plus it will swing and get banged around.
The other downside is as mentioned above- the inside texture is not good for flow (although some OEM applications use similar stuff).
would i be better off buying this. It includes all the clamps and that to hold it together.
http://intense-racing.com/Merchant2/...3800_Induction
or should i just buy the tube and do it myself
i totally disagree with some of you. i been running the flexible for the last 3 years without any issue. the tube is better than my old thrasher box. before i went full size intercool i was getting couple degrees of knocks that's why i went with the tubing and hell yeah it's cheap, but it works that's why went this route. in the pic you can see how the filter sit with no supporting at all. no supporting is need, the tube itself will support the filter. mine sit same way like that the last 3 years. the cone is a 9" S & B. the wall inside is not as smooth as the pcv or other after market tubing, but it's way better than stocker for sure. if this is your DD i wouldn't recommend to have your filter sit that low like mine.
I had a buddy with an SRT4 have the filter fall out at the strip, and he ran it over. Thats not the first time I've heard of someone having their FWI filter fall off when the 1 hose clamp was the only thing holding it on. I've also seen the hose wear through from the filter bouncing around and the hose rubbing on a metal corener.
Not saying that it won't work or anything though- its been used on many cars. Personally for a daily driver, I prefer to put as much of the filter in the fenderwell as you can from the engine compartment, and then using that plastic roof flashing to seal off the backside of the filter from the engine bay. That gives you the pretty cool air from the fenderwell, while still reducing tubing length and number of bends.
Do you disagree that tubing with ridges on the inside flows worse than tubing that is smooth on the inside?
The hose clamps can loosen, especially if the filter is suspended midway in the fenderwell with nothing to sit on- so it just bounces around.
this is the stainless tube i use to connect the filter to the tube. it's the silver tube like in the pic.
btw where did i said tube with ridge on the inside flow better than smooth tube??? all i refer to is the tube is not as bad as some people saying they are.
