finally a CAI
Old Nov 24, 2007 | 04:15 PM
Chucks88SS's Avatar
Default RE: finally a CAI
Looks really good!!
Did you do the paint on the engine cover yourself? Cause that looks real good too. If so What did you use? What was your technique??
Old Nov 24, 2007 | 04:48 PM
2000_BLACK_SS's Avatar
ORIGINAL: Chucks88SS
Looks really good!!
Yes i did that my self. I used some of the high temp paint that you can get at any auto parts store.
i first sanded the entire cover because i had painted it before and waqs starting to come off.
I then cleaned the cover of all the old paint dust and every thing.
Then used an adhesion (SP) promoter on the whole cover
Sparyed 3 coats on the cover about 15 mins apart
then i let it dry for a week and then i taped off around the ribs of the cover and used some "Por 15" paint and a foam brush and went over the ribs and "V6" "3800 series ll" then after letting that dry for a day i went over it all with two clear coats of spray paint.
03SS
i had an Ebay intake before and i just used the pipe from that.
Thanks for all the compliments
Right know i am painting the outside of it with a high temp flat black spray paint with ceramic in it. So the inside of the box will be like a mirror finish and then i am going to be putting some leds shinning on it to light it up.
Old Nov 24, 2007 | 05:05 PM
Hi `Luke,
Thanks for taking the time to post how you painted your
engine cover. I hope that the other member's do the same.
A special panel of the MCF has met to check out your work.
They looked close at everything.
[:-] Check it Out [:-]
After a long/intense inspection, they concurred on the highest grade, and they give you a big A + WoW
Luke, thanks for `Sharing,
Space, & the Bums : )
Old Nov 25, 2007 | 12:06 AM
Chucks88SS's Avatar
Like i said before, it looks great, and im sure the next step will look even better. Dont forget pics of that too. Thanks for the painting tips. i might try it out on a junk yard cover to see if i can handle it. Then ill try mine!
Old Nov 25, 2007 | 07:34 AM
I am also ordering another engine cover from ZZP for $15 and am going to try some of the ideas from ClubGp with there wire mesh cut outs for it.
http://www.clubgp.com/newforum/tm.as...=1&smode=1
Take a look at some of the engine covers on here they are amazing.
Old Nov 26, 2007 | 08:32 PM
Chucks88SS's Avatar
Wow just got done drooling all over my comp.
Im really interested in trying it now. not sure if i want flames or just black and red stripes.
Old Nov 26, 2007 | 10:53 PM
Yeah there are some amazing engine covers on clubgp. It was amazing how nice some of them look.
Old Nov 27, 2007 | 08:14 AM
mad717's Avatar
Very nice job on all of your work. Your car looks awesome.
Old Nov 27, 2007 | 09:05 AM
Awesome job and those GP cover look great!
Old Nov 27, 2007 | 09:18 AM
06MCLTZ's Avatar
The intake and the cover looks badass. How long did it take you to make your shield for your intake.
