exhaust system
Old Jul 17, 2006 | 11:52 PM
zipsayain's Avatar
Default exhaust system
Would Putting an hole new exhaust system on my 2003 ls . Make a big diffence?
If so want brand would you go with?
Old Jul 23, 2006 | 11:58 PM
z34phoenix's Avatar
Default RE: exhaust system
Yes. the new monte's have a flaw in the exhaust... it is called the U-bend. it is a bend in the exhaust used to protect the O2 sensor thatis after the cat. it is a major restriction in the exhaust. also all the piping is press bent so replacing that Ubend and the remaining exhaust with mandral bent pipe will free up a good amount of power... esp if you have an intake.
Old Jul 24, 2006 | 04:11 PM
montejass's Avatar
ORIGINAL: z34phoenix
Yes. the new monte's have a flaw in the exhaust... it is called the U-bend. it is a bend in the exhaust used to protect the O2 sensor that is after the cat. it is a major restriction in the exhaust. also all the piping is press bent so replacing that Ubend and the remaining exhaust with mandral bent pipe will free up a good amount of power... esp if you have an intake.
Yeah, what he said. The Ubend on 01' up is before the CAT if not mistaken. How much effieciency is gained by replacing all other pipe do you think? I've always wondered if the cost beyond the Ubend upgrade was worth it...
Old Jul 25, 2006 | 08:37 PM
z34phoenix's Avatar
the U bend is for the post cat O2 the pre cat o2 is in the engine bay by the fire wall... so the Ubend will be after the cat. yes the gain will be significant if replacing everythign after the cat. and even better if replacing the cat too.
BeachBumMike
May 4, 2008 10:10 AM
old dude
Dec 10, 2007 07:16 PM
81monte
Nov 11, 2007 07:23 PM
ExplosiveSoundz
Jun 20, 2007 06:52 PM
cain45
Jun 18, 2006 04:54 PM
