exhaust manifold melting spark plug wire
what do you guys use to avoid the spark plug wires from touching the exhaust manifold? Is there a wire cover that I can use to avoid the exhaust from melting the wire? Heat resistant wire?
Well, you can do one of two things..
The boots clamp onto your spark plug, so you should be able to rotate it... HOWEVER, if that doesnt work on your stock wires, you could use the following:
Protect-A-Boots
Hope that helps.
Protect-A-Boots
Hope that helps.
4th Gen ('81-'88): Spark Plug wire 2 short?
Jake Long
04-03-2015 05:31 PM
Yellow_Monte
13
03-25-2008 09:24 PM
