exhaust manifold melting spark plug wire
Old Oct 18, 2007 | 01:38 AM
pcp's Avatar
pcp
Default exhaust manifold melting spark plug wire
what do you guys use to avoid the spark plug wires from touching the exhaust manifold? Is there a wire cover that I can use to avoid the exhaust from melting the wire? Heat resistant wire?
Old Oct 18, 2007 | 02:25 AM
ExplosiveSoundz's Avatar
Default RE: exhaust manifold melting spark plug wire
Well, you can do one of two things..
The boots clamp onto your spark plug, so you should be able to rotate it... HOWEVER, if that doesnt work on your stock wires, you could use the following:
Protect-A-Boots
Hope that helps.
Old Oct 18, 2007 | 04:46 PM
pcp's Avatar
pcp
do you think it's ok to use one of those braided stainless steel wire cover? I think they are used for motorcycle.
John Kolakoff
Dec 19, 2020 07:42 AM
Jake Long
Apr 3, 2015 05:31 PM
Video
Jul 26, 2013 11:47 AM
thewhitestcarlouknow
Jun 29, 2008 07:01 PM
Yellow_Monte
13
Mar 25, 2008 09:24 PM
