Exhaust leak!!
Old May 27, 2010 | 01:14 AM
JOETHEPRO's Avatar
Default Exhaust leak!!
Since i replaced my downpipe i have heard a small exhaust leak. Could it be that there is no gasket from the header collector to the downpipe. The stock pipe has a groove that fits into the other end. The downpipe i bought is a flat fit to the recessed stock collector. Does that seem like the problem. Should i just order a gasket to be safe. Thanks...
Old May 27, 2010 | 01:27 AM
nitehawkjcb's Avatar
I'd definately get a gasket. And make sure your bolts are tight on the downpipe/header.
Old May 27, 2010 | 08:36 AM
What downpipe are you running?
On my ZZP DP, I have a gasket on both ends.
Old May 27, 2010 | 11:10 AM
JOETHEPRO's Avatar
i have a magnaflow 2.5 high flow cat. i heard that if you over tighten the bolts connection will warp. ???
Old May 27, 2010 | 02:36 PM
From my experience with an L67 downpipe, it's hard to even tighten - I can't put enough force on it to make mine warp. Perhaps yours is different.
MonteSquarlo
Dec 16, 2012 06:18 PM
Overdose666
Mar 19, 2012 09:04 PM
wht02monte
Apr 7, 2010 01:20 AM
smitty911
Mar 3, 2010 05:11 PM
moonlitmagik
Sep 14, 2009 02:05 AM
