6th Gen ('00-'05): Exhaust Gaskets (have already checked out some other threads)
Hey Guys,
Replaced my Catalytic Converter a few months ago with a magnaflo direct fit downpipe/cat assembly; I also replace the downstream o2 sensor. Everything went great, except at the time i didnt receive gaskets with my order. being as impatient and Stubborn as I am, i just cleaned the original front and rear gaskets (which are numbered 7 and 8 in diagram below) and stuck them back in with no issues. Once i was complete repair, sounded great, and there was no leaks or issues. Well I kicked myself in the *** because now months later my gaskets are toast.
I rolled the Monte up on the ramps and rolled underneath.
Thankfully I had covered all my hardware in anti-seize during the last repair so removal was quite easy. However while underneath the car i noticed this years winter was not kind to my resonator.
So once the Catalytic converter was out of the way i dropped the rest of the exhaust system and brought it into the shop and cut out my resonator. Took some measurements and headed to the part stores.
After pricing a new resonator and reading many posts on the forum i decided to go with a straight pipe Resonator-Delete. So back home i go, take some more measurements and head to local shop and get a pipe bent to replace the resonator and part of the intermediate pipe, Low and behold there is pre-existing part exactly to the measurements i need.... (give or take an inch or two)
Cut old flange off resonator, welded onto new straight pipe, welded new straight pipe to intermediate bend. After bolting up the cat, i installed my gaskets and bolted the flanges together.
BEST REPAIR I'VE EVER DONE! I Love the new sound, i especially like that its coming from the back of my car instead of underneath it.
I would recommend a resonator delete to anyone with intentions of replacing resonator.
All in all i took me a couple hours, 20 dollars for gaskets, 30 dollars for new pipe, and a little bit of welding. Sounds Awesome!
Anyone looking for Catalytic Converter flange gaskets the following part numbers are 7 and 8 in the diagram below
walker #31605 flange gasket
walker #31578 flange gasket
5th Gen ('95-'99): Turn Signal Issue (Researched but Not Seen in other threads)
Little Cheese
Feb 15, 2015 06:11 PM
Furder2010
Apr 29, 2013 02:23 PM
