EGR delete
Old Apr 11, 2010 | 08:28 PM
aussiek2000's Avatar
Default EGR delete
I am considering deleting the EGR on my car and have a tuned PCM made to go with it. My question is, does anyone have an EGR delete? It doesn't really matter which engine, I just want to know how much performance increase there is. If the difference isn't noticeable, I wont bother.
Old Apr 11, 2010 | 09:54 PM
Budsjlm's Avatar
if u live in a state that does testing don't bother you will never pass, with these newer cars i have heard that it can decrease mpg
Old Apr 11, 2010 | 11:38 PM
No power increase at all. EGR only recirculates exhaust gas at part throttle- never at idle (engines have a hard enough time keeping a steady smooth idle as it is) and never at WOT.
I turned off EGR (well I set the pcm disable temperature so high that it would never come on) on my GTP after seeing all the carbon buildup in the intake manifold. After taking like a 2-3 mpg hit (even after a little tweaking on my tune), I decided it wasn't worth it and re-enabled it. Not much way to get around it- at part throttle where you don't need all the power, it partially fills your cylinders with inert gas- meaning less fresh air coming in and less fuel needed also.
I do have it completely removed on my monte- thats partially for looks, partially for weight savings, but mostly for the fact that I don't want it plugging up my intercooler core (something most people don't have to worry about).
Old Apr 12, 2010 | 04:04 PM
yeah man, whats said above^^^ it will waste gas and it closes all the way when you got the gas all the way down(WOT).
Old Apr 13, 2010 | 04:32 PM
Thanks guys. If there is no performance increase, I'll just leave it on.
Old Apr 14, 2010 | 05:48 PM
yeah, good idea. the only real problem with having an EGR is that it can get clogged or gunked up.
siouxcity04montess
Aug 15, 2010 12:23 AM
dustybird3
Feb 5, 2008 08:18 PM
gonsailin
Dec 3, 2007 03:40 PM
96Carlo
Nov 26, 2006 03:04 PM
DiscoStu
Feb 15, 2005 10:55 PM
