Crossover Pipe input!
I was thinking about doing that also..... the wrap your talking about, is that the stuff you have to wet first and then wrap around? I dont know much about the wrap but it sounds like a good idea, cuz my engine seems to get pretty hot so anything would help! A link or product info would be helpful on that stuff to! Thank you!
the wrap i use at work you don't have to soak. i don't know what brand it is, but it works fine without soaking. the DEI stuff, says it's optional to make it more pliable. IMO you could get it done w/o soaking. you should also use a silicone sealer spray to "waterproof" it from the elements. otherwise, what could happen is water gets soaked into the wrap and rusts your pipe. if you live in a dry climate, you might not need this.
i wanted to wrap my crossover pipe but decided against it cuz it looked to be a pain in the a$$, not so much to wrap it in the car, but to apply the silicone sealer spray. i found the spray necessary in my case since my monte is a daily/all season driver and is exposed to salt spray, rain, snow that can splatter up there.
http://www.designengineering.com/pro...asp?m=sp&pid=9
you can get DEI wrap or any other brand wrap and the spray at any auto parts store or pretty much auto parts website ie summit, jegs, etc.
dougg
11-08-2009 09:17 PM
