cat ?
You will get a code and check engine light. The rear o2 sensor will detect too much flow if you just put a pipe in instead. You will have to get a tune to get rid of the code. Other than that you are alright.
If it has not been tuned out or in a '00-'03 solved with an O2 emulator or resolved with the anti-fouler trick on the O2, you will more then likely throw a P0420 code.
If you are interested, I should be able to adjust your PCM if needed. Please review my thread below:
https://montecarloforum.com/forum/pr...impalas-42773/
