Bad CAT
Old Feb 25, 2007 | 03:51 PM
thatrealcreolenigg's Avatar
Default Bad CAT
i had a cat get clogged about a month and had it replaced. when i it was finished i could tell there was a major difference in performance and that it must have been going bad for a months, but now it seems as if im losing power again. could my cat be getting clogged again and if so what could be making it clog so fast
Old Mar 8, 2007 | 12:35 AM
fwoggybaby's Avatar
Default RE: Bad CAT
What kind of CAT did you have put in? I just went through this and after 6 months I think I might have gotten it straightened out...
Old Mar 10, 2007 | 02:58 AM
Default RE: Bad CAT
i dunno i had it dunno at a shop
Old Mar 12, 2007 | 11:27 PM
fwoggybaby's Avatar
Default RE: Bad CAT
Well if it is at all possible you might want to find out. I had a Magnaflow put on mine and even though it was a "universal"CAT the one they put on was totally wrong. Like I said earlier it took 6 months to figure out the problem. It you can't figure out which one you had put on, see if you can have someone check the tempature before the CAT and after. It should be higher coming out then going in. If not then you probably have the wrong one on. Contrary to popular belief not all universals are the same...If you want to go with the Magnaflow the correct part # is 94806....hope this helps
Old Mar 13, 2007 | 09:12 AM
Caboose's Avatar
Default RE: Bad CAT
Fwoggy, I tried to check my cat for the temp before and after, but he just kept hissing at me,
I think he hates me, .......
Old Mar 13, 2007 | 10:22 AM
wiz kidd's Avatar
Default RE: Bad CAT
lmao!!
TMoney
Apr 9, 2014 09:32 AM
ahill
Aug 9, 2012 08:32 AM
kicker
Apr 2, 2011 09:41 AM
skylark65
May 10, 2010 10:07 PM
SIC LSX
Mar 30, 2010 11:36 PM
