99 monte 3.8 bad mpg and cat
Old Aug 4, 2012 | 01:05 AM
ahill's Avatar
Default 99 monte 3.8 bad mpg and cat
my gas mpg has been relly bad latley ie betwen 15-16 mpg. this has been going on for about a year. i have no check engine codes on and have tried various forms of driving. second of all has anyone over removed the cat. does the motor still run alright and does the car gain mpg and horse power
Old Aug 4, 2012 | 01:12 AM
ahill's Avatar
oh i have done a complete tune up all new filters,new starter,alternator,waterpump,and the rail pressure is about 3 lbs below spec
Old Aug 5, 2012 | 05:43 PM
1996Monte_Carlo's Avatar
sounds like a bad fuel pump to me if it is 3 below
Old Aug 6, 2012 | 08:03 PM
z34phoenix's Avatar
here are a few things to look at:
you put new plugs in? if so what plugs and what are they gaped at?
what type of oil you running? a high mile synthetic blend might help a little
get a new pcv valve
check for vacuum leaks.
Old Aug 6, 2012 | 08:38 PM
Also change your o2 sensor on your rear exhaust manifold.
Old Aug 7, 2012 | 11:16 AM
ahill's Avatar
New delco plugs and new wires. Standard conventional mobil 5000 oil, new pcv valve and there are no checkengine lights on. Would the rear o2 throw a code if its bad. Wouldent lower fuel pressure give better mpg
Old Aug 9, 2012 | 08:32 AM
z34phoenix's Avatar
actually with lower pressure the spray pattern would not mist like is should and cause wasted fuel.
TMoney
Apr 9, 2014 09:32 AM
Josh Rovou
Aug 8, 2013 11:10 AM
sal23
Jul 9, 2013 05:46 AM
lunchboxor
Apr 18, 2013 09:48 PM
ltrain925
Oct 22, 2007 10:44 PM
