Backfirng, Bogging
Old Dec 5, 2010 | 04:44 AM
mhallen13's Avatar
Question Backfirng, Bogging
My 75 is running a M4MC quadrajet over a 350. A couple nights ago "flames" were coming out and tonight it backfired. The problem is intermediate and when it the problem is present the slightest push will get power but past that the pedal just feels boggy unless you floor it, risking flames and backfire. The idle screws are turned about 2- 2.5 turns out. The bigger idle screw on driver side is pushing a little to raise idle(). I have heard things about the APT(?) or maybe this is the accelerator pump. Also I am not totally carburetor terminology savvy.
Old Dec 5, 2010 | 05:22 AM
I hope one of our talented/expert tech member's can help you with your problem.
When was your last tune ? Plugs/wires/ignition etc ?
How many miles on your 350 ?
Has the carb been rebuilt ?
It helps if you can put as much information as possible into your post to help member's ~>Help you...
It's sometimes difficult to help with just words and not being there to hear/test drive, so post as much information about your problem that you can....Good Luck
Old Dec 5, 2010 | 05:41 AM
mhallen13's Avatar
Exclamation
Thank you for the friend invite & response, God Bless you. Roughly 40,000 miles maybe less. Wires replaced within a few weeks and I checked the new ones for damage earlier tonight. Timing set at ~6 degrees. I did not replace spark plugs but I got the car in August. Carb was rebuilt(paperwork says and overhaul) maybe in 2001.
When I first got the car, (no custom exhaust or any work on carb by me) it had a slight delay from stop to accelerating and would sometimes stall from stop.
At first the choke was suspect. I cleaned it(just spray choke cleaner) and observed it to find the it was functioning(based on my observations) and didn't appear to be a problem. Then I discovered the idle mixture screws. Probably tuned more those times then I needed but I felt I was learning.
Then I learned of the other idle screw on the driver side which actually lowers and raises the idle rpm(to best of my observations).
Now through all this the slight delay never left entirely and the car would often still stall from say backing up.
I felt the engine bogging the night the flames spat and all I thought I had modified was the idle screws.
This sounds like the accelerator pump? I read this can be a gradually worsening problem and sounds suspect to my problem.
If you need more details, HOLLAR
Old Dec 5, 2010 | 05:46 AM
mhallen13's Avatar
Once more, inconsistently the engine will run proper it makes me jealous.
Old Dec 5, 2010 | 06:03 AM
Below is from a Google's Search...I hope it may help until one of our expert member's can make a suggestion/solution to your problem. Check out the below links:
\Car backfiring and shooting flames after cam install - LS1TECH
19 posts - 15 authors - Last post: Aug 20
LT1-LT4 Modifications 1993-97 Gen II Small Block V8 ... I fixed the overheating problem, the second is from today. ... 1996 Chevrolet Camaro Z28 SS #597 M6 395.3 SR ... on the drivers side are right and I can see flames shooting out the ds header when it backfires, along with the passenger side. ...
www.ls1tech.com › ... › LT1-LT4 Modifications - Cached - Similar
Get more discussion results
View topic - olds 350 starting problems • GBodyForum.com - '78-'88 ...
8 posts - 5 authors - Last post: Jun 12
All it does is backfire(like shooting flames out of the carb) never started ... The proper firing order for the v8 is 1-8-4-3-6-5-7-2 you ...
gbodyforum.com/viewtopic.php?f=13&t=19710 - Cached
Answers.com - Chevy 350 Questions including "How much would a '72 ...
wrote the first answer to How much horse power does a 1984 350 chevy v8 engine .... your temperature sending unit is defective ,you could have problems in your. ... 180 it then backfires. New Heads cam installed? ..... What causes flames to come out of the carburetor when you try to start the vehicle chevy 350? ...
wiki.answers.com › ... › American CarsChevrolet - Cached - Similar
engine backfires through carb at higher rpm
9 posts - 4 authors - Last post: May 15, 2007
FSC - Chevy Truck Forum ... Keep in mind that like all auto problems, there is sometimes 10+ different options. ... O2 GMC RCSB 4.8L V8 AUTO 3.73's rebuilt/beefed up 4L60E(at 43000miles) Matching Ninja 500r ... oh and when i say backfire i mean like a flame shoots out its driving me crazy lol ...
www.fullsizechevy.com/showthread.php?268398...backfires...at... - Cached
*******What causes an engine backfire?
......................... Click above link & read: It's your homework assignment for 2day : )
12 posts - 11 authors - Last post: May 8, 2009
It has shot flames out of the carb before I know this for a fact because ... had the same problem with an Edelbrock on a 327 that would backfire and ... the history of chevy v8's, savman1, Engine, 32, 08-11-2010 11:30 AM ...
www.hotrodders.com › ... › Tech HelpEngine - Cached - Similar
Old Dec 5, 2010 | 09:34 AM
Ricks 2006 SS's Avatar
Hey. Back firing thru the carb sounds like a timing issue! Check that & your spark plugs. Also if you have a vacum leak. It will run like crap. Also check to see if your spark plugs wires are on tight. Also their might be a leak around the carb base.
Old Dec 5, 2010 | 12:07 PM
mhallen13's Avatar
The backfiring I was aware of was from the exhaust pipe(Sorry I didn't state that earlier). Umm I am pretty confident its not the timing, I have checked it twice and the problem intermediately comes and goes. I can't imagine a vacum leak causing this large of a problem that comes and goes either. If I'm wrong correct me and thank you.
Old Dec 5, 2010 | 03:18 PM
mhallen13's Avatar
Sorry if I shut you down but you may be right Rick I always noticed fuel around the carb and ignored it.
Old Dec 5, 2010 | 06:19 PM
monte07's Avatar
i will check if it is getting the proper spark from the coil and i will double check the gasket for the carb as well because it might need a thicker one. what i mean is the gasket wich the carb sits on. also check the bowles on the sides of the carb to see if it is getting to much air or might be leaking. also see if it is the fuel pump or fuel system feeding the system to much one time to little the next. after running the basics like you did leaves few check points.
Tom.M
Mar 5, 2013 04:38 PM
Enzo354
18
Jul 2, 2009 10:23 PM
5thgear8084
Aug 12, 2008 07:22 PM
Bob
Feb 16, 2008 10:32 AM
