6th Gen ('00-'05): Montys bogging down
Old Feb 25, 2013 | 11:40 PM
Tom.M's Avatar
Default Montys bogging down
Challenge for ya'll. For the past few weeks as I start to accelerate my car seems to start losing power. It was doing it as i was driving a steady 60MPH today also. We thought it could be the transmission, but it is feeling a little like my old Camaro when its Mass Air Flow sensor failed. There's no service light on yet. What do you guys think? Its a 2002 3.8L engine with a butt load of miles.
Old Feb 26, 2013 | 12:01 AM
Red Nightmare's Avatar
Probably a slim chance, is the oil pressure ok?
My first car had issues after the oil pan gasket blew, I slowly got a loss of power at higher speeds, and just got worse and worse. Then one morning I started it up, it gave a bit of struggle that day and going home I got a horrific rod knock. Once it got to temperature pressure dropped to nothing.
I seriously doubt that is your problem, but you never know..
Old Feb 26, 2013 | 12:20 AM
Tom.M's Avatar
I should look into that. The pressure looks good but there is an oil leak I and I do need to change it.
Old Feb 26, 2013 | 12:24 AM
How bout everyones favorite....A bad catalytic converter? Just a guess and I have no first hand experience either.....
Old Feb 26, 2013 | 07:54 AM
03SSLE's Avatar
How long since your last tune up? What about the fuel filter? Fuel pump/Regulator pressure? Another possibility could be the fuel. The chemical composition of ethanol attracts water and becomes more apparent during the colder months. Using an additive (like Sta-Bil or Heet) will aid in purging water from your fuel system but will not improve performance. The next time you fill up try a different station. If the car runs 'normal' then avoid the prior station during the Winter.
Old Feb 26, 2013 | 10:11 AM
Tom.M's Avatar
Its been about two years since its last major tune-up. Ive been running around a lot and end up going to a lot of different stations. I'll try the additive, it couldn't hurt. The fuel filter may be an issue. The car did live in a dusty, dirty place. Also don't say catalytic converter, I don't want to deal with changing that right now I'll have to get back to you guys.
Old Feb 26, 2013 | 10:22 AM
Whens the last time you chnaged the air filter? Have you done an oil change recently? (might explain the ticking!) These engines do require a relatively normal maintenance schedule..(since you said it lived in a dust laidened environment). I would consider cleaning the TPS as well as the MAF for good measure! This could be multiple issues causeing this running issue! Maintenece , Maintenance, Maintenance!!!
Old Feb 26, 2013 | 04:28 PM
aussiek2000's Avatar
+1. Sounds exactly like a cat
Old Feb 26, 2013 | 04:40 PM
meow.
Old Feb 27, 2013 | 12:07 PM
Tom.M's Avatar
Well it's off to the shop. I didn't want to take it in around Phoenix. Don't have a place here I trust yet.
