Air intake questions,help?
Ok you guys don't be mad at me but I'm probably going to ask some questions that have been asked and answered like a million times here, but forgive me.I'm a noob with cars and this is my first car.
I currently have a HAI, I know it's bad, but that's why I'm here to ask questions. I was just wondering on what to use to make an airbox?where can I get the material from?what would be the easiest way to go about making an airBOX, not a wall.lol does anyone have any specs, instructions, and experiences with this that they don't mind sharing with me?
Also, is an FWI more effective than a CAI? I know gains are minimal on N/A cars but which one gives more low end torque,if any?
A FWI isn't more beneficial than a proper CAI, they are just easier to make because you don't need to build a box.
To build a box, do some research on materials that reflect heat, use cardboard for a template, then make a box from that.
Heres a pic. of one I made ....
ok so if the CAI is done properly, it should be atleast somewhat more efficient right?or are they basically the same, just different cosmetically?
@zjerry, where can i find scraps of aluminum like that?and the coupling with the extension can only be found at autozone?i went to home depot once looking for something similar to that but no luck.While i was there i was also looking at aluminum sheets, but i think i need to add an extension to the tube first. and what did you use to cut the tube shape for the aluminum box?do you have it insulated?if so how did you insulate it?
Spectre/3 1/2 in. dia. x 6 in. straight polished aluminum air intake tube
Price:
$16.99
Part Number: 9519
Spectre/3 1/2 in. intake system to 3 1/2 in. inlet or 2 3/2 in. components together black air intake tube coupler kit includes coupler and 2 pcs. clamps
Price:
$11.99
Part Number: 9571
Category: Coupler
aluminum I had in garage I bent it hammer and 2x4 and clamp cut with jegsaw
Not insulated at this time may insulate later...
Price:
$16.99
Part Number: 9519
Price:
$11.99
Part Number: 9571
Category: Coupler
Ive been thinking about building a box from this. maybe you could try this.http://www.homedepot.com/Building-Ma...atalogId=10053
that doesnt seem like a bad idea, considering that thats insulation wrap. Itll skip the whole step of insulating any box i make.it probably wont be the best looking one but should get the job done right?
so i plan to get the extension and the make a box out of this material and mount it where the original air box used to go.time to start taking down measurements i guess!thanks to all you guys that sent me in the right direction with this!
does any one know if that material is stiff to create a box?or will i need to has something stiff to connect the ends to form a box
came across this person's idea.
pretty ghetto, but i do live in the ghetto after all!lol
i like it tho
what do you guys think?
http://www.audizine.com/forum/showth...-for-under-75?
when he started, you would think that its going to look crappy and what not, but the final product actually looks nice!
i like it tho
