air intake?
Old Jan 8, 2014 | 03:20 PM
dgm's Avatar
dgm
Default air intake?
Hi, i gutted my factory airbox and tried using cone filter in it, no go pcm takes space. So question is would a panel k&n/spectre panel in box or 9"cone filter flow better. I can make a panel cai box later...thanks. Also tried to load pics but keeps sayng failed... any ideas.
Old Jan 8, 2014 | 05:00 PM
You can always link pictures through photo bucket...
You have to make a minimum of 10 posts before you will be allowed to post pictures directly...
A cone without a box is just sucking hot air within the motor compartment.
which totally defeats the purpose of having a cold aire intake setup.
Your better off in the meantime replacing the original filter box..until you can complete a true cold aire intake system with it boxed in... IMO.
Old Jan 8, 2014 | 05:19 PM
You could make your own that's what I did..
Old Jan 8, 2014 | 05:37 PM
Jerry
That's a really nice way to do it...
Now I want one....lol Like yours...
Old Jan 8, 2014 | 05:38 PM
tps221's Avatar
I have a drop in spectre filter and the thing works amazing for 20 bucks even get the sound on throttle but the stock air box on my car is really a good cold air intake there's no reason to screw with it on a fifth gen
Old Jan 8, 2014 | 05:54 PM
Originally Posted by STUMPMI
Jerry
This is what I used .. I bought 2 because the first one I cut up didn't work..
$4.99
Oatey 15-in x 11-in Thermoplastic Roof Flashing
Old Jan 8, 2014 | 06:02 PM
Thanks Jerry very cool!
Old Jan 8, 2014 | 06:14 PM
When someone decides to gut the air box, the goal is to have a larger opening that exposes more of the panel filter so the engine can have less air restrictions.
If you want a cone filter, you're best doing what Jerry did of fabbing a Fender Well Intake (FWI) or buy/build a Cold Air Intake.
Old Jan 8, 2014 | 08:09 PM
l67ss's Avatar
I have actually seen dyno results posted that showed the "hot air intake" actually made more hp than one of the good fwi(which are supposedly better than most cold air intakes
Old Jan 9, 2014 | 09:43 AM
On a boosted engine a HAI isn't as negative, because the supercharger will heat up the air anyway.
However, I have seen real life dynos where the HAI negatively affected the dyno power. I've seen tons of dynos and sheets where everything out of stock actually lost power.
The only times the HAIs really show a rise in power, is when they pop the hood and put a fan in front on the dyno. That's artificial since no one drives with their hood open
