87' SS carb and chip questions
Old 11-03-2006 | 01:21 PM
Mike87Monte's Avatar
Default 87' SS carb and chip questions
tried searching but not to many 80's style SS's, but i have an 87' SS with torque converter, dynomax exhaust, edelbrock headers, edelbrock intake manifold and a crane cam. i need an carburetor and i was looking at edelbrock. any suggestions on which one to look at. i have the 5.0L 305 motor. i was also looking into a performance chip too? any suggestions? i was looking at JET chips, but dont know what to look for. Looking for more hp and torque.
Old 11-03-2006 | 04:18 PM
z34phoenix's Avatar
Default RE: 87' SS carb and chip questions
if its a carb, why would it have a computer? unless its for spark.
Old 11-03-2006 | 10:43 PM
85_SS's Avatar
If you want to keep the car running off the ECM, you will need to stick with the original CCC Q-jet and distributer. The ECM controls timing and fuel mixture through these devices which are not reproduced in a compatable aftermarket part. The stock Q-jet is a fantastic carb and don't let anyone tell you otherwise - the small primaries and huge secondaries offer great mileage and performance in one package. The stock Q-jet can be easily modified to flow ~750cfm, but they are originally limited to 600 or so. I run the stock CCC system on my 350, as do many others. Some are even running a big block on the CCC system with a custom chip.
Performance chips aren't very useful for a CCC vehicle since the ECM is out of the loop at WOT - the carb acts like a standard carb allowing max fuel into the carb, only to be metered thereafter by the rods. I have tried a few in my car and you cannot notice a difference IMHO.
www.montecarloss.com is a much more suited resource for those interested in pre-5th gen Montes
Old 11-06-2006 | 01:52 PM
04 Intimidator's Avatar
I agree with 85_SS on most points. The Q-Jet is an underrated carb and really does do a good job for gas milage and WOT there is no arguing that. But the Edelbrock is better.
I would specifically pick up a Performer series 750 cfm considering your intake manifold and headers. Also the Crane cam will take advantage as well. The Q-Jet can do it and without problems but I just found tuning to be easier on the Edelbrock. Vic's boys know what their doing.
As for the chip I would scrap the idea as you're asking for problems...or at least in my experience Go with a MSD Ignition system to improve spark.
Old 11-06-2006 | 02:33 PM
85_SS's Avatar
Carb brand is preference, and I will agree the Q-jet does take a bit more background knowledge to tune.
Just be aware that to go with a non CCC qjet, you must completely eliminate the CCC system, including the distributer. This may not be an option if you require emissions testing.
Old 11-18-2006 | 11:46 PM
88ss408's Avatar
if you have to keep it stock get your carb rebuilt upgrade your ignition system (msd,accel)or whatever and go with a ZZ4 prom that should work . but if you dont have to stick to stock i would go with a edelbrock carb 600-750cfm and i would change to a HEI distributor with the coil in the cap and get rid of the ECU completlely
85ssmonte355
04-22-2015 03:44 PM
Kracktheskye
03-02-2011 04:52 PM
lougreen03
02-21-2011 06:01 PM
countryboy07
12-30-2007 12:29 AM
87monte
01-16-2007 05:09 AM
