84 - 88 SS Dual Exhaust Question
Old Mar 7, 2007 | 06:18 PM
88ss's Avatar
Default 84 - 88 SS Dual Exhaust Question
I have an 88 SS, and from what I remember, years ago, when I had my 84, someone told me to buy a certain year Trans cross member from an El Camino, or Cutlas. The reason wasthat it allows you to run true duals, and the pipes can go under both sides with no problem. Anyone know of one that works?
Thanks Shawn
Old Mar 8, 2007 | 02:38 AM
RippedMantis's Avatar
Default RE: 84 - 88 SS Dual Exhaust Question
88ss,
A few years ago I had dual exhaust put on my '86 LS. The crossmemeber off of dual exhaust vehicles has two humps that allow the exhaust to stay a little closer to the body to prevent clearance issues. My LS only had single exhaust, so it only had one hump in the crossmember. I had to take off my crossmember, cut/whack another hump in it so that one side did not stick down alot further than the other. If you have the tools, you could just make your own hump, or find one off a G body such as you listed above. I do believe that would work.
Old Mar 8, 2007 | 02:13 PM
88ss408's Avatar
well i did mine i to ways my old 86 ss i used the stock crossmember and drilled a 3 in hole and put a pice of pipe to reinforce it and then for my 88 ss that i have now i did a costum crossmember in square tubing somthing like this
http://www.geocities.com/gforcejohn/
if you have welding skills the stuff to do it is not that expinsive and is way better than any stock pice so that what i did
04MonteLS
Mar 15, 2017 03:19 PM
ben_98monte
Jan 24, 2009 07:40 AM
vita
Jul 13, 2007 11:57 AM
2000_BLACK_SS
Sep 25, 2006 11:20 PM
afb`
Apr 12, 2006 02:09 PM
