04 3800 ss i wana do an exhaust what kind should i do
i have just a k/n cold air intake on the car no and its not s/c so the cold air makes all the sound it sounds good but i wan a better sound and more power also
You have a lot of options for power and sound.
- Front ZZP Plog to reduce restrictions
- ZZP DownPipe and high flow Cat
- Headers
- Resonator delete
- After market mufflers
I'm running a PLOG, 2.5" ZZP Stainless down pipe and a resonator delete (the delete was because I got tired of after market ones blowing baffles on me, but had a small change in sound, but nothing big IMO).
- Headers
- Resonator delete
You might look into having an exhaust cut out installed. Can give you some great sound and extra power for little money spent. We pulled 30 more H.P. on the dyno with the cut out open on a built motor.
on ur guys monte's
is the intake louder then the exhaust it is on mine so i that the main reason to do this and i was thinning of doing straight pipes from the cat's 2 borla mufflers or a a borla system from the cat;s back what do u guys think
Well my exhaust is louder than my intake, never hear my intake so very much, but then I have a lot going on under the hood.
In my opinion you will need a larger diameter exhaust system from the down pipe back to really notice a significant sound difference.Anything else is going to a marginal sound change, spend a few extra dollars and make it worth the time and effort and get a noticable sound difference. Inquire at a local performance or quality exhaust shop and ask them about what I'm saying, then you don't have to take my word on it. As far as the actual muffler's go and your final selection Borla or who ever it's what you like hearing, to listen to some tones you can go to the Magnaflow Website and perhaps others and listen to muffler sound clips. I ended up with Magnaflow, has the tones I like. good luck, let us know how things are developing...
Magnaflow Video "2006 Impala SS"
Here is my Monte and it's exhaust cut out open and closed. Magnaflow exhaust
Turbocharged 2002 Monte Carlo SS exhaust cutout - YouTube
