Passkey bypass - successful
Old Feb 20, 2012 | 11:26 AM
JaxJim's Avatar
Default Passkey bypass - successful
My 1996 Lumina would suffer intermittent issues with the Passkey security system. The ignition had worn to the point were the resistor chip in the key was not being read by the computer. So, occasionally the security system would shut down the starting system for the required 2-3 minutes. Annoying! I bought a bypass module from Ecklers Corvettes for $27. It simply plugs into the wiring harness under the dash - bypasssing the ignition. Works great. Since the replacement - no starting issues, no security light on the dash. Would work on 1995-1999 Montes as well. You just have to know the resistance of your key and order the correct bypass.
Old Mar 13, 2012 | 03:07 PM
Skye Bowen-Grigsby's Avatar
Default help!!!
my car is a 2001 any ideas what would fix mine im having the same problems
Old Mar 13, 2012 | 03:25 PM
Passlock is harder to bypass than Passkey.
Old Jul 20, 2012 | 08:44 AM
Cleo0243's Avatar
Im having the same problem with my 99-3.1L. Every since I bought this car I've had starting problems. At first I had problems with the VAT System. Security Light Flashing, Turning the key getting nothing(Dashboard lights up). After spending $$$.$$, i finally have the VAT System disconnected/By-passing the system. This worked for awhile. I replaced new starter. Alt, and Battery too. Now Im having problems again, sometimes I turn key and get nothing. wait a few mins. and she starts right up no problem.
Peterl
Jun 19, 2013 06:40 PM
jim1405
Apr 2, 2012 04:51 PM
IcantDo55
Jan 14, 2010 06:59 PM
skylark65
Aug 27, 2009 03:35 PM
GrandPaDave
Mar 17, 2007 09:41 AM
