how do you change the Ignition
Old Jan 11, 2013 | 05:22 PM
jason307's Avatar
Default how do you change the Ignition
how do you change the ignition switch on a 2005 ss? can you just go through to radio opening? is it just the two screws that hold it in? and do i have to worry about any of the security things getting messed up since im putinng the same key cylinder back in.
Old Jan 11, 2013 | 07:00 PM
jim1405's Avatar
Check out this link. It's for an Impala but it's basically the same thing except you will have a screw in the left hand side of the glove box to remove for Montes. I replaced the ignition switch in my 2001 and it was pretty easy and completely solved multiple problems. I know using GM parts is often recommended but I tried the cheaper route with a Dorman switch since I had good luck with their drivers side power window switch when a more expensive replacement failed within a week. So far so good on the ignition switch. Just my 2 cents....
Oh, and no problems with any security settings, I used my same lock cylinder too.
7th gen ignition switch replacement/access - Chevy Impala Forums
Old Jan 12, 2013 | 01:06 AM
MonteSSS's Avatar
https://montecarloforum.com/forum/ge...no-heat-40736/
i explained it with tutorials on hhere just scroll to bottom of page one ask if you have questions ill be on here everyday at some poitn
Old Jan 12, 2013 | 01:07 AM
MonteSSS's Avatar
oh its the same guy haha my bad
dcnaser
Mar 25, 2012 07:40 PM
drmrgal
Apr 8, 2011 05:11 AM
01BlkSS
Jun 7, 2007 01:56 PM
BeachBumMike
Oct 5, 2006 10:18 PM
zipsayain
Mar 14, 2006 09:38 PM
