Electric Lock issue, BCM location
On my 02 the Key fob does not unlock the doors but it turns the lights on. It also locks the doors. It is not the locks because I can unlock the with the inside switch.
I went to the dealer today for another reason and they said it could be the BCM and it would cost about $250 plus 1.5 hours labor. I guess you can't just plug it in you have to program it on the car.
Anyone know where this is located on the car? Anyone had similar issues?
Thanks,
Thanks,
I found out where it is. It is right under the drivers side of the dash.
Here is some info on programing it...
Hi
Unless you have a Scan tool with GM TIS2k programming abilities, you'll need to have the BCM reprogrammed at either a dealership and or a repiar shop with reprogramming capibilities.
Here is the EXACT GM replacement and reprogramming procedures, if intrested.
Important:
• Read this procedure carefully and completely.
• The BCM will not function properly if the Setup New BCM procedure is not performed.
• Perform the Programming Theft Deterrent System Components procedure after successfully finishing the Setup New BCM procedure. Refer to Programming Theft Deterrent System Components in Theft Deterrent. If the procedure is not performed after a BCM replacement, the following conditions may occur:
- The vehicle will not be protected against theft by the Passlock system.
- The engine will not crank or start.
Connect a Scan Tool (Tech 2) to the Data Link Connector (DLC).
Turn the ignition switch on.
Select Diagnostics and input all of the required data when prompted by the Scan Tool (Tech 2).
Select BODY CONTROL MODULE.
Select SPECIAL FUNCTIONS.
Select Setup New BCM.
Note, Input all of the required data when prompted by the scan tool.
Select Setup SDM Part Number in BCM, and follow the onscreen directions.
Select New VIN, and follow the onscreen directions.
Select Option Configuration, and follow the onscreen directions. .
Select Point of Sale, and follow the onscreen directions. .
Exit back to the SPECIAL FUNCTIONS menu.
When the BCM, VIN, Point of Sale and Option Configuration have been entered, proceed with the Theft Deterrent Re-learn procedure.
If the scan tool displays UNABLE TO PROGRAM BCM. BCM IS SECURED, then the BCM must be replaced and this procedure must be repeated on a new BCM.
NOTE: After the completing the above procedure , personalization of the BCM defaults to default settings. Inform the customer that the personalization settings must be reset.
Important
After programming, perform the following to avoid future misdiagnosis:
Turn the ignition OFF for 10 seconds.
Connect the scan tool to the data link connector.
Turn the ignition ON with the engine OFF.
Use the scan tool in order to retrieve history DTCs from all modules.
Clear all history DTCs.
Hi
Important:
Important
6th Gen ('00-'05): Pass lock/ignition cylinder/BCM problems
dbaldwin
07-02-2014 12:32 AM
6th Gen ('00-'05): tranny lock issue?
Sbrunelli
01-21-2013 08:41 PM
