Wheel bearing going bad??
Old Jul 11, 2006 | 03:06 PM
montejass's Avatar
Default RE: Wheel bearing going bad??
Actually, this sounds more related to the brakes.
My memory took a while to snap to this thread, but mine made the same noise until I replaced my rotors and pads. I am pretty sure it was the rotors causing the noise but it's gone now. Do you have a slight warpage vibration in the wheel when you brake?
Old Jul 11, 2006 | 04:53 PM
wiz kidd's Avatar
not me..no vibrations
Old Jul 11, 2006 | 06:10 PM
montejass's Avatar
When is the last time you had brake service performed?
I would not experience the vibration mentioned unless I was really hard on the brakes. Under normal driving I did not feel the warpage.
Old Jul 11, 2006 | 08:01 PM
wiz kidd's Avatar
i just got the car on the road about 2 weeks ago...so never..lol...its only got 7000 miles on it
Old Jul 11, 2006 | 08:25 PM
toeknee94's Avatar
Wile driving the car and the noise is present sway the car left to right. What you are doing is loading each wheel bearing left to right. If the noise starts and stops when you turn the wheel you have a bearing isse. When you are turning left you are loading the right wheel bearings, when turning right you are loading the left side. You want to sway the car a good amount and let the body roll to get weight to load the bearing. If the noise does not start and stop then it might not be a bearing.
Old Jul 11, 2006 | 10:51 PM
Yellow_Monte's Avatar
No my brakes used to vibrate when I got on them hard, so I took it in and got carbon ceramic pads and the rotors re-surfaced. That solved that and they are great now. I also just got the wheels re-balanced and that fixed the high speed vibration I was having.
TMoney
Apr 9, 2014 09:32 AM
myfirstbowtie
Mar 8, 2011 06:25 AM
willie8701
Sep 29, 2010 05:29 PM
mmiller1448
Jul 5, 2010 11:22 PM
2000_BLACK_SS
Oct 11, 2008 05:22 AM
