transmission coolers????
Old Dec 21, 2012 | 05:30 PM
Dam20735's Avatar
Default transmission coolers????
do you all think that it would be a good idea or no to add a transmission cooler to my 02 supercharged monte carlo?
Old Dec 21, 2012 | 06:19 PM
cxt35's Avatar
it won't hurt, you can't over-cool your engine, but you could sure over-heat it...
Old Dec 21, 2012 | 06:29 PM
01 Monte SS's Avatar
You shouldn't have a problem with the trans fluid getting too hot. Adding a cooler is just adding additional places for possible leaks. I've never experienced any overheating of my transmission in the past 3 years. If you plan to do track runs all weekend long, you might want to consider additional cooling. I personally still wouldn't do it. The risk seems to outweigh the reward. Nothing to gain, and a lot to lose if something goes wrong, IMO.
Old Dec 21, 2012 | 06:38 PM
cxt35's Avatar
And Trans coolers cool your engine and transmission... by the way
Old Dec 21, 2012 | 06:40 PM
cxt35's Avatar
Default heres my ride 4:10 gears with turbo 350 tranny and of course trans and engine cooler
Old Dec 21, 2012 | 06:52 PM
Budsjlm's Avatar
Trans cooler is built into the radiator but it is not a bad idea to add a external one becuase heat is transmisions enemy,
I have one on my 01 that i stole from my 85 but that was becuase the replacement radiator i bought was missing the fittings so i could not use that and could't have my car down n out any longer!
Old Dec 21, 2012 | 09:30 PM
I run 2 external tranny coolers, 1 engine oil cooler and a fuel cooler. Heat is your tranny's enemy, an external cooler will add to the life of your tranny in the long run......
weizie
16
Jan 15, 2012 07:13 PM
Great White North
Mar 31, 2006 12:55 PM
hempen1
Jan 30, 2006 08:56 PM
dh0765
Oct 14, 2005 06:08 PM
zeroKOOL
May 17, 2005 07:04 PM
